BulletProofing 2nd Gen. Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TellYurMomThx69, Aug 23, 2021.
Thread Status:
Not open for further replies.
  1. Aug 23, 2021 at 4:04 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You could sew cloth around a thin AR-500 plate and slip it into the map holder pocket in the back of the seats. That would be an easy way to prevent being shot in the back.
    Aside from that bulletproofing the entire truck would add a couple thousand pounds of steel and cost a fortune.
    Jojee117 and TegoTaco like this.
  2. Aug 23, 2021 at 4:07 PM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    OP is a one post wonder so likely just bored at work on a Monday morning...
    EDIT: I stand corrected - they've just joined the conversation
    verynearlypure likes this.
  3. Aug 23, 2021 at 4:11 PM
    mosccat
    Mark
    2020 OR
    If you care for them why not move to somewhere less dangerous, doesn't need to be somewhere expensive...
    sgage likes this.
  4. Aug 23, 2021 at 4:17 PM
    JKidTaco13
    JKidTaco13 Well-Known Member
    HNL, HAWAII
    2013 PreRunner
    i seriously thought you were asking for a build like this.. lol
    all jokes aside tho, stay safe out there with the shooting :laser:.
    Slashaar likes this.
  5. Aug 23, 2021 at 4:19 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Bro, if you’re concerned about the Texas heat, then you’re not THAT concerned about your safety.
    Ever just think about…firing back if the situation arose?
    So you put a few plates in your taco..
    You’re door panels are sheet metal. You will be shot all the same, so you need to line those doors with level 1p Kevlar. Adds weight to taco.
    But you’re basically in a 3rd world country right? And you’re concerned about rifle fire, so you need to add ballistic plates. So you need your panels lined with that too. Glass needs to be pulled out and replaced with bullet proof glass. Adds another 500 lbs to taco. MINIMUM.
    You’re engine is probably aluminum. What if the enemy shoots your engine and mobility kills you, then surrounds your vehicle??
    Next post, we should start talking IED’s, defeating bullet proof glass. If you can’t afford to move, you probably can’t afford to properly bullet proof your truck. A few plates aren’t going to do anything but give you a false sense of security. Assuming things are as bad as you describe. Which is nothing compared to Detroit. Lol
  6. Aug 23, 2021 at 4:20 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Coming Friday: "Up-armored my Taco. Miles per tank now only 100!?!?! What gives?"
    Sidney Vicious likes this.
  7. Aug 23, 2021 at 4:24 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    If you are worried about being shot, then you arent staying low profile enough. Buy a shit box with a reliable drive train. The more deep body rust, the better.
    verynearlypure and fatfurious2 like this.
  8. Aug 23, 2021 at 4:26 PM
    beorn the fat
    beorn the fat Well-Known Member
    Or, you could try
  9. Aug 23, 2021 at 4:27 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    wait so you have a gun also?
    Is this bulletproofing so you dont shoot out of your car? or so someone doesnt shoot in..
  10. Aug 23, 2021 at 4:28 PM
    TellYurMomThx69
    TellYurMomThx69 [OP] Member
    Texas
    2010 Tacoma 4x4 SR5 6 speed MT V6
    TRD quickshifter
    Moving isn't an option. I am seeking advice from people that know the process and options for bulletproofing a 2nd gen. Tacoma. Once again any feedback would be appreciated. For those that say this doesn't warrant a thought haven't been to Houston.
    I know weight will be an issue, and I was planning on updating suspension with heavier duty springs. There are a couple of dealerships in the area that offer bulletproof vehicles, but they are super expensive. Any helpful feedback would be appreciated. Thanks.
    Sae68 likes this.
  11. Aug 23, 2021 at 4:29 PM
    fatfurious2
    David
    Ashburn, VA
    buy a welder and some steel
  12. Aug 23, 2021 at 4:36 PM
    Sharpish
    Brian
    Glue Kevlar vests to the inside of all your door panels lol
    Torspd and fatfurious2 like this.
  13. Aug 23, 2021 at 4:41 PM
    ndmak
    ndmak Well-Known Member
    for real OP, an actual bullet proof tacoma would likely only be built by a government contractor who doesnt spend their time on tacoma world, or a cartel contractor and you can contact them on tacomaworld.com/cartel but they only type in spanish.
    crackils, Jojee117, henryp and 4 others like this.
  14. Aug 23, 2021 at 4:44 PM
    beorn the fat
    Seriously, by the time you actually bulletproof your truck, it’ll be too slow to be worth driving and with the money you’ll spend- you would have a down payment for a place somewhere else.
    604, Key-Rei and dfanonymous like this.
  15. Aug 23, 2021 at 4:46 PM
    #35
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You've never driven through Gary Indiana eh?
  16. Aug 23, 2021 at 4:46 PM
    #36
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
  17. Aug 23, 2021 at 4:50 PM
    #37
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    wi_taco and Torspd like this.
  18. Aug 23, 2021 at 4:53 PM
    #38
    Key-Rei
    Key
    Florida
    If you are legitimately concerned about taking rounds your beat option is to bulletproof yourself first.
    Get a vest, get a helmet, get full coverage stuff with the leg pieces etc find a used EOD suit or something.
    Normal steel plates will not stop bullets like you think they will.
    Using only 5.56 I have shot through 3/8" plate of A36 mild steel.
    Plating your truck in A500 will exceed not just your trucks weight capacity but your budget.
    The guys over in the sad box had F350's beefed up to be bulletproof and the doors were always falling off them and suspension breaking due to the weight.
    I'm sorry you feel the way you do and maybe you are in a really rough area but when I lived in the ghetto the best protection was to look broke and be friendly.
    bijick, blu92in99, Jojee117 and 5 others like this.
  19. Aug 23, 2021 at 4:55 PM
    #39
    -MEH-
    -MEH- Makes people wish they knew floridaman instead
    Overpriced Toyota, Ragged out old Porsche
    Outside of Kabul getting that bad?
    Chase tactical has proper NIJ cert plates for a good budget, and revision is probably as good as you'll get for reliable NIJ helmets. Just don't buy into the milspec crap, those pads on the ACH is a cost saving measure and will increase the likeluhood of head trauma over a good harness system.
  20. Aug 23, 2021 at 4:55 PM
    #40
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    With the weight you'd need an engine with more torque and you wouldn't be able to roll down your windows. The glass alone would cost more than the truck. I'd say do what others do in america with so many guns in the country...
Thread Status:
