Bully Dog GT-T+ Toyota Tuner
Discussion in 'Performance and Tuning' started by tcBob, Aug 28, 2013.
  1. Sep 3, 2013 at 11:57 PM
    #41
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Since it says not legal in ca, will we be able to unflash the tune before smog? Then reflash ?
  2. Sep 4, 2013 at 5:57 AM
    #42
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    You should be able to take it back to stock tune then remove it as needed.
  3. Sep 4, 2013 at 6:16 AM
    #43
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Sweet. Thank you.
  4. Sep 4, 2013 at 6:26 AM
    #44
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Pretty amazing items this unit can do, value with function and options:
    TUNING OPTIONS
    Stock
    This tune allows the user to download special features and functions.
    Tow
    This will give our drivers a higher average horsepower over what they had before as well as a powerful torque improvement that pulls their engine performance to an improved level with an additional 7 horsepower.
    Regular
    This will help your engine to show its true power using its inherent but hidden horsepower and torque! Enjoy an additional 9 horsepower!
    Premium
    This will give your engine the maximum level of power and torque available! You can enjoy up to 25 horsepower in gains and 30 ft/lb depending on application.
    TUNING FEATURES
    Speed Limiter
    This option allows drivers to set limits that will keep their vehicle under a certain speed or remove the speed limiter.
    Shift Points (Auto Transmission)
    Change the RPM level at which your automatic transmission will shift gears when the throttle is wide open.
    Driving Coach
    The Driving Coach is invaluable for teaching great efficient driving habits. Using momentum and minimizing your acceleration and braking will help your engine access the full mileage available in every gallon of gas that you put in your tank. The Driving Coach uses an efficiency bar to display when you are using your momentum correctly and using a grading system, will develop habits that will benefit your fuel economy. You have the option to use an alert system for when your driving becomes inefficient but of course you can choose to turn off these alerts in the GT T + menu.
    Display
    The GT display is the key to a successful tune. With over fifteen vehicle parameters that can be monitored and displayed, you can watch your engines performance and keep tabs on all the measurements you care about. With one screen displaying 4 gauges at one time, and easy navigation, you will see the difference our tuner can make for your engine from a second to second basis. Multiple display options let you change between gauges and a full color display let you customize your screen to your preference.
    Day and Night Mode
    This feature offers two modes for your GT T+ display. If switching between day and night modes doesn't happen automatically, simply push the bottom button just to the right of the display screen and your background will go turn black, which dims your GT for minimal distraction for night time driving. Pushing the top button to the right of the display screen will make your display go back to a brighter daytime mode.
    DTC's
    Codes used by vehicle manufacturers to identify problems; this information is gathered by the engine computer and accessible through the vehicle's diagnostic port (OBDII).
    Data Logging
    Want to record what your engine performance is doing over a period of time? Use the data logging feature to download results from a drive logged for later use. If you want to record engine performance over a period of time, use this feature.
    Performance Testing
    Someday, you may get the chance to drive where there are no posted speeds. Take your Bully Dog GT T+ with you, because it's a racing man's best friend. Our GT T+ can give drivers a quarter-mile time and a 0-60 time so you can post a personal best. It comes with a drag tree on display so you can really feel what it's like to unleash your engine.
    Safety Warnings
    Pyro Warning
    Your pyro warning will sound when your pyro temperatures become too hot. This can be set up in your GT T+ menu.
    Coolant Temperature
    If your car begins to overheat, you will be the first to know with the use of this warning. This will notify when your coolant temperatures are getting too hot. This is customizable in the GT T+ menu.
    Transmission Temperature
    This gauge option shows the transmission temperature.
    Special Features
    Display and Lighting
    Display Ex Off
    This changes the brightness when canceling the lights for the indicator light of the combination meter, A/C indicator light and clock.
    Display Ex On
    This changes the brightness when dimming the indicator light of the combination meter, A/C indicator light and clock.
    Foot Light
    This sets the time the Outer Foot Light is on.
    Interior Lighting
    This will turn the interior light on when the ignition switch is turned from "ACC" to "LOCK". This will also turn on the interior light, ignition light and step light on when the door is unlocked by the door key cylinder.
    Light Sensitivity
    This adjusts the sensitivity of the lights
    Light Auto OFF
    This will light the headlight for a time after the doors are closed with the ignition switch turned ON and the light control switch is at HEAD or AUTO and the headlight is ON.
    Light Time On This function changes the time between when the doors are closed and the lights go off when the light control switch is at HEAD or AUTO, and the headlight is on.
    Door Lock Functions
    Auto Lock
    Doors on the vehicle lock automatically after the vehicle reaches a certain speed.
    Auto Lock on Shift
    This locks the door when the lever shifts out of the P range.
    Auto Unlock on Shift
    This unlocks the door when the lever is shifted into the P range with the ignition ON.
    Unlock All Doors on Shift
    This unlocks every door but the driver door when the driver door is opened after the ignition is switched off after a certain time.
    Key Cylinder Functions
    Power Windows
    This makes the driver window (and all windows, depending on vehicle grade) and sunroof close if the driver window control is held closed. If the driver door window control is held open, the driver's door window (and all the windows, depending on vehicle grade) and the sunroof will open.
    2 Turns Open All Doors
    This unlocks only the driver door when the key UNLOCK button is pushed twice. When this setting is switched OFF, the key UNLOCK button will unlock all the doors.
    Sunroof Operation
    This will open the sliding roof if the door switch is held to UNLOCK and the ignition switch is OFF. This will also close the sliding roof if the door switch is held to LOCK and the ignition switch is OFF.
    Sunroof Action
    This selects the opening direction of the sliding roof when holding the driver side door key unlocked for a certain time when the ignition switch is OFF.
    Key Fob Functions
    Wireless Control
    This is used to turn the wireless door lock ON or OFF.
    Horn Chirp on Lock
    This turns the wireless buzzer response function ON or OFF.
    Open Door Warning
    If a door is open when vehicle is being locked by the wireless door lock, a buzzer will sound.
    Panic Function
    The "ON" setting will enable the Theft Deterrent System by pressing and holding the Panic Button. Use the Lock Button if the Panic Button is unavailable.
    Wireless Auto Lock
    This automatically locks doors after they are unlocked with the wireless key.
    Auto Lock Time
    This will change the amount of time from unlocking the door(s) with the wireless key to re-locking them automatically.
    Optical Flash on Lock
    This is used to turn ON or OFF the hazard answer back of the wireless door lock.
    Unlock Driver Door
    Use the GT to disable this feature so all of your vehicle doors will unlock with one press of the button on a remote door lock unit.
    Power Back Door
    Wireless PBD Operation
    This function changes the operation of the PBD by transmitter.
    PBD Buzzer
    This function will adjust the volume of the buzzer while the PBD operates.
    Security
    Entry Delay
    This will change the Entry Delay Time, or the period before starting the warning, by the Passive Mode.
    Passive Mode
    This will set the Theft Deterrent System in 30 seconds after the Driver door is closed and the Key is removed from the Ignition Key Cylinder.
    Warning Broken Glass
    This will turn the Glass Break Sensor ON or OFF.
    Warn by Horn
    This turns the glass break sensor ON or OFF. It is only functional when the vehicle has a glass break sensor.
    Warnings
    Key Reminder Sound
    This function changes the times at which the key reminder buzzer will continue to sound.
    Key Reminder Volume
    This changes the volume of the key reminder buzzer.
    Seat Belt Chime
    This changes the seat belt reminder chime.
  5. Sep 4, 2013 at 12:29 PM
    #45
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    How come there is nothing for 2005-2008 Tacomas?
  6. Sep 4, 2013 at 3:17 PM
    #46
    czwhat
    czwhat Member
    I wish they would post dyno results for it already. I think 900 bucks is a little much to ask when there's no proof of what it can do.
  7. Sep 4, 2013 at 4:47 PM
    #47
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I know that this is off topic because you guys aren't doing anything with the 2TR FE 2.7, but that's a useful piece of information... :)
    So Tacoma driveline losses account for around 32 horsepower.
    I could extrapolate those same driveline losses to obtain a more accurate baseline for the 2.7. Factory specs 159hp at the crank, so that would work out to 127hp at the wheels.
    This puts my baseline results of 147hp (with only header and intake) in more realistic terms. That means a gain of 20hp with the header and intake. I had been comparing it to a weaker at the wheels baseline run that netted only 119hp, because that was the only totally stock 2.7 baseline run in existence.
    An intake gain of 20hp is much more realistic for just a header and intake and no tuning. :)
  8. Sep 4, 2013 at 4:56 PM
    #48
    tooter
    Greg
    Los Angeles
    $900?... fuk. :eek:
    I had no idea it was that much money. I'm sure that high end products like that will meet the needs of others who are going balls to the walls modifying their engines, But that level of tuning control for my little 2.7 is far beyond my needs, which is more like maybe just some MAF tuning if anything.
  9. Sep 4, 2013 at 5:15 PM
    #49
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    From Bully Dog:
    "Expected number on the N/A Tacoma are about 10-15 horses"
  10. Sep 4, 2013 at 5:47 PM
    #50
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Watched the live feed on YouTube today 2010 supercharged tacoma made about 20rwhp more with the Bullydog tuner
  11. Sep 4, 2013 at 6:57 PM
    #51
    czwhat
    czwhat Member
    If they had a coupon for early adopters I would give it a try. The truck in the video looked like it had a pulley and exhaust.
  12. Sep 4, 2013 at 7:00 PM
    #52
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I saw that too. Would like the details on the truck tested
  13. Sep 4, 2013 at 7:55 PM
    #53
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    So just to confirm...Not available for 2012 4.0 Taco?
  14. Sep 4, 2013 at 8:02 PM
    #54
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Supercharged 2009-2013 Tacoma
  15. Sep 5, 2013 at 9:38 AM
    #55
    jdavis92
    jdavis92 Well-Known Member
    Boise, ID
    2010 Regular Cab, 2.7L, 5spd
    Stock
  16. Sep 5, 2013 at 11:05 AM
    #56
    pcabinatan
    pcabinatan Well-Known Member
    Avondale, Arizona
    K&N Intake, 35w 6K HID's, Plastidip badges
  17. Sep 5, 2013 at 2:30 PM
    #57
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    We just got word our's have shipped for stocking. I'll have them by Monday. Ill see if I can get any TW pricing for you guys. It's hard with new electronics.
    The price is high, but if you factor in what a UniChip costs, this is worth it for sure since you get all the heads up gauges and the other functions. It does a lot of cool stuff. Can't wait to play with one!
  18. Sep 5, 2013 at 3:23 PM
    #58
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    We are offering these to all TW members. Call 702.979.1577 or email sales@tapautoparts.com for pricing or with any questions.
    I am getting overloaded with emails & calls on this item. I am trying to reply to you all but I need to take care of all the test guys that volunteered. I will have more info tomorrow for you all!!
  19. Sep 5, 2013 at 3:34 PM
    #59
    jdavis92
    Boise, ID
    Stock
    By "killer" do you mean 66% off?
    Not having done a thorough cost/benefit analysis, I'd say anything more than $300 is just an expensive toy.
  20. Sep 5, 2013 at 4:03 PM
    #60
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    We mean a fair price for the product as compared to the MSRP price.
    I mean look at it this way. Pretty much any truck mod you buy is a toy. I have a customer who bought a Trophy Truck from gieser this year, cost him over 300k - One expensive ass toy! Personally, I just picked up a new cold brew coffee maker, crap cost me 250 bucks!!! But Toys make life interesting & fun. If you only bought out of necessity, your life would be pretty boring. You should see me stare at this coffee maker when it operates, to me it was worth the expense.
