Bully Dog GT-T+ Toyota Tuner
Discussion in 'Performance and Tuning' started by tcBob, Aug 28, 2013.
  1. May 26, 2014 at 1:05 AM
    #621
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    Bully dog sold their company?
  2. May 27, 2014 at 6:46 AM
    #622
    theallpowerfuljon
    theallpowerfuljon Well-Known Member
    Jon
    Wichita, KS
    09 TRD Off-Road 15 T4R Limited
    I had a DSM back in the day that did the same thing -- what was happening was the stock ECU could sense the piggyback's fuel changes and slowly trimmed the car back to stock. Happened about once every two weeks.
    I don't know how that is possible in this situation since the BD is supposed to reflash, but that's what it reminded me of.
  3. May 31, 2014 at 8:11 AM
    #623
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
  4. May 31, 2014 at 9:47 AM
    #624
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
  5. Jul 16, 2014 at 11:42 AM
    #625
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Why?
  6. Jul 20, 2014 at 9:45 PM
    #626
    C00P07
    C00P07 Active Member
    Cooper
    Kennesaw, GA
    2013 Silver TRD Sport Tacoma
    Marathon Seat Covers
    I have the same issue with my 2013. When I try to cruise down a hill to help my mileage my truck decides to down shift, make my rpms jump and my truck jerks back from the deceleration. Glad I'm not the only one. I'm assuming it is programed that way to keep control over the truck when you are towing large loads, but that's just a shot in the dark.
  7. Jul 23, 2014 at 10:52 AM
    #627
    CanadaToy
    Greg
    Toronto
    If you're worried about that, just push the shifter into neutral. Then, slip it back into drive near the bottom of the hill.
    However, your theory is wrong. The reason you are engine braking, is to save fuel. When you are engine braking, your injectors are OFF. When you are in neutral, the engine is idling, using fuel. This if verified by mine (and many others) scangauges.
    if you don't like engine braking, i guess you were never raised driving a manual transmission vehicle?
    Konvict KROG likes this.
  8. Jul 23, 2014 at 11:40 AM
    #628
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I use that technique regularly. ;) As well as left foot braking. :eek: Call me :goingcrazy:
    CanadaToy likes this.
  9. Jul 30, 2014 at 8:19 PM
    #629
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I've watched my scan guage when shifting to neutral vs coasting and there is no difference in mpg. With the cruise set its a different story.
  10. Jul 31, 2014 at 6:35 AM
    #630
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There's a setting on the SG to tell it if you have injector cutoff.
  11. Jul 31, 2014 at 6:44 AM
    #631
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    I'm not an expert but I'm pretty sure I read on here that the auto stops circulating atf in neutral and that can burn up the transmission if your just rolling around in neutral
  12. Jul 31, 2014 at 6:52 AM
    #632
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    There is a rpm threshold, when you are under it your injectors are still working. I will from around 50 mpg while coasting down a hill to 999mpg when I am in gear and off the gas. Like others have said, you might not have the scan Guage setting on.
  13. Jul 31, 2014 at 3:01 PM
    #633
    gray223
    SE Missouri
    2014 Tundra Limited
    I meant to say ultra guage. I've just put it into neutral when going down a hill and the instant mpg doesn't change.
  14. Jul 31, 2014 at 4:51 PM
    #634
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I do a lot of first gear driving up and down steep rural roads and so have plenty of time to observe the DFCO threshold.
    As rpms are rising, DFCO engages at 1,800 rpms. The ECU releases control back to the idle circuit at 1,400 rpms as rpms are falling.
    Greg
  15. Sep 28, 2014 at 8:47 PM
    #635
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Selling my bullydog GT tuner. Had it on my 2012 supercharged taco but no longer need it. Have everything including packaging $500 shipped
  16. Sep 28, 2014 at 9:45 PM
    #636
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    How come you don't need it?
  17. Sep 29, 2014 at 4:07 AM
    #637
    tmreyes1
    T-Rey
    TX
    2017 TRD
    No longer have my taco
  18. Oct 22, 2014 at 2:57 PM
    #638
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Alright so I have been readying through all these post. Im about to pull the trigger on one of these and I just need the honest truth. IS IT WORTH IT? Im not supercharger I have CAI, Exhaust, URD MAF, and a throttle body spacer. Im looking for the obvious fun and playing (acceleration and speed) but I would also like a little more towing power as well. So can anyone that has this give me their input please? Thank you in advance
  19. Oct 22, 2014 at 3:16 PM
    #639
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    u read all the posts?
    really?
    I think ur better off with a URD MAF calibrator
  20. Nov 24, 2014 at 4:50 AM
    #640
    WHT.RUS
    WHT.RUS Well-Known Member
    Will my 2013 truck run lean with SC + 2.85 URD pulley + bully dog set on premium?
