Bully Dog GT-T+ Toyota Tuner
Discussion in 'Performance and Tuning' started by tcBob, Aug 28, 2013.
  1. Mar 7, 2016 at 11:50 AM
    #681
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    It comes with a disc with the software, and you need to have a serial to usb cable and driver...
    Basically you are remapping the TPS for more or less fuel...
    If you add an intake or exhaust you need to remap, even a stock truck will benefit from mapping...
    He has instructions you can read on pdf... maybe search google.....
    The supplied map is good but really tame for every day use and it's a good starting point...
    raising a few tenths makes a big difference.... from 10.1 to 10.3 ect...
  2. Mar 7, 2016 at 10:01 PM
    #682
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    I've got a Trd intake Doug thorley long tube headers and Trd catback exhaust any suggestions
  3. Mar 7, 2016 at 10:03 PM
    #683
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Hope the BDT has those in its tune bank
  4. Mar 7, 2016 at 11:24 PM
    #684
    shr133
    Muskego, WI
    2010 V6 Sport
    Gadet@urd will have a map for long tube headers...
    But you will definitely pick up some power with a good tune...
    With Toyota we are kind of on our own for tuning but I think there is a Toyota shop in your area....
    Just change 1 area at a time by a few tents at a time....
    here's some info...
    http://www.vaglinks.com/OBDII/Gadgetonline.com_U-Tune.pdf
    my current map...
  5. Mar 8, 2016 at 2:22 AM
    #685
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    True doing this yourself is not all that difficult to do, but I think for a regular guy who doesn't know anything about this stuff messing with the tune on your own is asking for trouble. Call up Gadget and have him help you with a better premade map or at the very least get yourself some scanning tools to monitor what is going on with the truck. This isn't something you want to do blind.
    Lord Helmet and shr133 like this.
  6. Mar 8, 2016 at 8:37 AM
    #686
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    I see the one side is the Rpms but what's the other v's?
  7. Mar 8, 2016 at 8:39 AM
    #687
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    I've got a scan gauge that I've been using for everything Toyota didn't put on the gauge cluster battery voltage trans temp mpg
  8. Mar 8, 2016 at 9:29 AM
    #688
    shr133
    Muskego, WI
    2010 V6 Sport
    Load in the form of voltage... MAF voltage......
    You can watch the map in live mode and you can see under power what part of the map you are using...
    At cruising speed you are around 1.3 - 1.4 volts and normal acceleration around 2-2.5 volts, full throttle around 3.5 volts...
  9. Mar 8, 2016 at 1:02 PM
    #689
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    It's TPS voltage and it varies between 0.8V (16%) and 4.1V (82%)
    shr133[QUOTED] likes this.
  10. Mar 17, 2016 at 8:20 PM
    #690
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    Can anyone send me the link for the cable to buy to do this
  11. Mar 17, 2016 at 10:56 PM
    #691
    shr133
    Muskego, WI
    2010 V6 Sport
  12. Mar 18, 2016 at 8:07 AM
    #692
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Interesting. I had issues with Gigaware for my Map-ECU2 connection.
  13. Jul 6, 2016 at 6:02 PM
    #693
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Thread revival!
  14. Jul 23, 2016 at 8:19 AM
    #694
    Bently
    Bently Active Member
    Scott
    2011 black tacoma
    fog lights installed tri fold tonneau cover Folding towing mirrors
    Thinking of getting the bully dog performance chip, What's your take on this?
  15. Jul 23, 2016 at 8:26 AM
    #695
    Tacoma SS
    Denver
    Dont
  16. Jul 23, 2016 at 8:44 AM
    #696
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    What he said
  17. Jul 23, 2016 at 9:27 AM
    #697
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I didn't even know Bully Dog came out with a chip just the tuner is all I heard about.
  18. Jul 23, 2016 at 10:44 AM
    #698
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I'm thinking he means the tuner. Lots of people don't distinguish between the two.
  19. Nov 20, 2016 at 11:30 AM
    #699
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    Read through this whole thing...
    So what I got from this is the BD tuner does not do much of anything for a naturally aspirated vehicle. +10HP at most?
    But for a supercharged truck, there are some gains to be had.
    I see a lot of people upset about the original $800 price tag for the HP gains... Now that these are priced at $400, and available used for $200 everywhere, has anyone had any luck with with a NA truck? Any new tunes available? Any luck at custom tuning?
  20. Nov 20, 2016 at 6:40 PM
    #700
    Hunter223
    Hunter223 Member
    Hunter
    2015 Toyota Tacoma
    K&N CAI and Flowmaster Dual Exhaust
    No luck on custom tuning where I am at. Nobody seems to want to touch a Toyota ECU. As for the bullydog, I tried it and it was useless. I'm stock with an intake and it does hardly anything. It's a fancy guage cluster. I went to a pretty high end performance shop and they said bullydog is a joke for gas vehicles. For BigRigs and diesels they are good. If you want a good tuner you would want an Edge tuner, only problem is they don't make those for Toyota. Your only tuning options are basically an aftermarket ecu or the URD Ucon which I have heard very good things about. Go to URD's website to check that one out before anything. Hope this helped
    DistortedAxis[QUOTED] likes this.
