Bully Dog GT-T+ Toyota Tuner
Discussion in 'Performance and Tuning' started by tcBob, Aug 28, 2013.
  1. Sep 15, 2013 at 7:11 PM
    #141
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Maybe not the actual speedo but what about the BD unit displaying the calibrated speed?
  2. Sep 15, 2013 at 7:12 PM
    #142
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    A $50 Garmin will do that to.
  3. Sep 15, 2013 at 7:13 PM
    #143
    tmreyes1
    T-Rey
    TX
    2017 TRD
    So does my $50 scan gauge but that won't tune my engine like the BD
  4. Sep 15, 2013 at 7:26 PM
    #144
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Yes, I can see how they could display a corrected speed on the BD display, maybe, but it is not going to change the speedo display.
    G
  5. Sep 15, 2013 at 7:28 PM
    #145
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I believe our speedo is mechanical... you'd have to change the gears. At least I think so
  6. Sep 15, 2013 at 7:32 PM
    #146
    Gadget@URD
    They stopped using mechanical speedos after the first couple years of the Gen 1 Taco.
    But, you can change the drive gear on the VSS in the trans to alter the signal ratio.
    G
  7. Sep 16, 2013 at 3:02 AM
    #147
    memario1214
    Colton
    Missoula, MT
    :facepalm: I'll shut up now
  8. Sep 16, 2013 at 5:24 AM
    #148
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    It's not nice to lie to an entire Internet board!!
    :D:D
  9. Sep 16, 2013 at 7:53 AM
    #149
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    hey i was just about to post about my new antenna, it lets me control the weather!
    Unfortunately its range is pretty short, so i can only control the weather in a 30 ft radius.
    It has a weather generator that is powered by the speedo cable. And as a benifit, it can also emit the brown noise (outside the vehicle)
    Most yota trucks have been electronic speedo since 92ish
    But just like carbs were available until 95, some oddballs still had mechanical cables later than 92ish..
    I personaly have never witnessed a 95.5 or newer (taco) with a cable, but i have heard of them. Whether or not there was ever one i can not say for sure.
  10. Sep 16, 2013 at 1:52 PM
    #150
    BD Wesley
    BD Wesley Active Member
    Wesley
    Aberdeen, ID
    Yes, you can correct the speedo on the actual GT. There is an option to correct by what percentage it is off. But we can't change the actual speedometer yet on the truck.
    Food for thought on why we haven't yet: It isn't controlled by the ecm.
  11. Sep 16, 2013 at 1:58 PM
    #151
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    If it were controlled by the ECM, we most likely wouldn't be able to change gear ratios without issues.....
  12. Sep 16, 2013 at 2:04 PM
    #152
    BD Wesley
    Wesley
    Aberdeen, ID
    I was merely mentioning that since what we tune is the ecm, and since the speed isn't transmitted through the ecm (like most other vehicles do), this is why as of now we're not able to adjust the speedo through the unit. But as I said, it's a work in progress. :)
  13. Sep 16, 2013 at 2:07 PM
    #153
    1strongone1
    1strongone1 Well-Known Member
    Jeff
    Iowa
    12 TRD Sport Supercharged
    Lifted, 33's, Supercharged, Volant Ram air CAI, Walbro fuel pump, 2.85 pulley, TRD exhaust, Bully Dog GT-T
    Does the unit come with a suction mount, or do you have to order that separate? Also, how do I know when an update is available, like when you unlock 70 hp for my Supercharged Tacoma?
  14. Sep 16, 2013 at 2:32 PM
    #154
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    I am still waiting on an RMA from Chas for my unit....
  15. Sep 16, 2013 at 3:38 PM
    #155
    MadToy
    Nick
    Huntersville, NC
    Was it DOA? My biggest fear with a handheld is having it crap out while writing to the ECM. Is there an easy recovery in that scenario?
  16. Sep 16, 2013 at 3:50 PM
    #156
    sfcadams
    Dan
    Elizabeth, Indiana
    Not DOA, it just will not do any of the special features that are mentioned....
    Display and Lighting
    Display Ex Off
    This changes the brightness when canceling the lights for the indicator light of the combination meter, A/C indicator light and clock.
    Display Ex On
    This changes the brightness when dimming the indicator light of the combination meter, A/C indicator light and clock.
    Foot Light
    This sets the time the Outer Foot Light is on.
    Interior Lighting
    This will turn the interior light on when the ignition switch is turned from "ACC" to "LOCK". This will also turn on the interior light, ignition light and step light on when the door is unlocked by the door key cylinder.
    Light Sensitivity
    This adjusts the sensitivity of the lights
    Light Auto OFF
    This will light the headlight for a time after the doors are closed with the ignition switch turned ON and the light control switch is at HEAD or AUTO and the headlight is ON.
    Light Time On
    This function changes the time between when the doors are closed and the lights go off when the light control switch is at HEAD or AUTO, and the headlight is on.
    Door Lock Functions
    Auto Lock
    Doors on the vehicle lock automatically after the vehicle reaches a certain speed.
    Auto Lock on Shift
    This locks the door when the lever shifts out of the P range.
    Auto Unlock on Shift
    This unlocks the door when the lever is shifted into the P range with the ignition ON.
    Unlock All Doors on Shift
    This unlocks every door but the driver door when the driver door is opened after the ignition is switched off after a certain time.
    Key Cylinder Functions
    Power Windows
    This makes the driver window (and all windows, depending on vehicle grade) and sunroof close if the driver window control is held closed. If the driver door window control is held open, the driver's door window (and all the windows, depending on vehicle grade) and the sunroof will open.
    2 Turns Open All Doors
    This unlocks only the driver door when the key UNLOCK button is pushed twice. When this setting is switched OFF, the key UNLOCK button will unlock all the doors.
    Sunroof Operation
    This will open the sliding roof if the door switch is held to UNLOCK and the ignition switch is OFF. This will also close the sliding roof if the door switch is held to LOCK and the ignition switch is OFF.
    Sunroof Action
    This selects the opening direction of the sliding roof when holding the driver side door key unlocked for a certain time when the ignition switch is OFF.
    Key Fob Functions
    Wireless Control
    This is used to turn the wireless door lock ON or OFF.
    Horn Chirp on Lock
    This turns the wireless buzzer response function ON or OFF.
    Open Door Warning
    If a door is open when vehicle is being locked by the wireless door lock, a buzzer will sound.
    Panic Function
    The "ON" setting will enable the Theft Deterrent System by pressing and holding the Panic Button. Use the Lock Button if the Panic Button is unavailable.
    Wireless Auto Lock
    This automatically locks doors after they are unlocked with the wireless key.
    Auto Lock Time
    This will change the amount of time from unlocking the door(s) with the wireless key to re-locking them automatically.
    Optical Flash on Lock
    This is used to turn ON or OFF the hazard answer back of the wireless door lock.
    Unlock Driver Door
    Use the GT to disable this feature so all of your vehicle doors will unlock with one press of the button on a remote door lock unit.
    Power Back Door
    Wireless PBD Operation
    This function changes the operation of the PBD by transmitter.
    PBD Buzzer
    This function will adjust the volume of the buzzer while the PBD operates.
    Security
    Entry Delay
    This will change the Entry Delay Time, or the period before starting the warning, by the Passive Mode.
    Passive Mode
    This will set the Theft Deterrent System in 30 seconds after the Driver door is closed and the Key is removed from the Ignition Key Cylinder.
    Warning Broken Glass
    This will turn the Glass Break Sensor ON or OFF.
    Warn by Horn
    This turns the glass break sensor ON or OFF. It is only functional when the vehicle has a glass break sensor.
    __________________
  17. Sep 16, 2013 at 4:01 PM
    #157
    MadToy
    Nick
    Huntersville, NC
    Since many of those functions aren't even available on a Tacoma, I would suspect that list is more generic than Tacoma specific.
  18. Sep 16, 2013 at 4:06 PM
    #158
    sfcadams
    Dan
    Elizabeth, Indiana
    Most of those functions if not all are ECU functions that should be able to be manipulated by the tuner, i.e. auto lights, lock on shift, interior lighting, etc. Regardless, it was advertised that it would do these functions on a Tacoma, which is 95% of the reason I bought it. I can't justify spending all that money just to tune the truck, even though that is a pretty spectacular feat in itself...
  19. Sep 16, 2013 at 5:53 PM
    #159
    Gadget@URD
    Those options are standard setups you can do with a Toyota enhanced scan tool or a Techstream. The first thing I do is turn off the seat belt dinger and the unlock when you shift into park. Those two things always bugged me.
    G
  20. Sep 16, 2013 at 6:08 PM
    #160
    Konvict KROG
    Louisiana
    I did not know that was an option.
    Now i wish i had one, but i dont think i have enough use to justify looking at buying one, im sure they arent cheap.
