Bully Dog- GT T+ Tuner (40450) TW Group Buy
Discussion in 'Group Buys' started by nfs257, Sep 7, 2013.
Thread Status:
Not open for further replies.
  1. Sep 7, 2013 at 1:06 PM
    nfs257
    nfs257 [OP] Well-Known Member
    DFW
    She gone
    So TAP Auto and I have teamed up to make a group by since the Beta tests didnt work out. Bully Dog released earlier than TAP expected. And since I have been talking to Chas since day one and I really want one we worked out TW pricing!!!!!!
    PM For group buy pricing.
    Follow this link: http://shop.tapautoparts.com/bully_dog/bullydog_programmers/40450tw/i-1797347.aspx
    Supported makes and models as of now
    TOYOTA 4RUNNER
    4.0L 2010-2012
    SEQUOIA (*NOT '11)
    5.7L 2008-2013
    5.7L FLEX FUEL 2010-2013
    TACOMA
    4.0L 2009-2011
    4.0L SUPERCHARGED 2009-2013
    TUNDRA
    5.7L 2007-2013
    Stock
    This tune allows the user to download special features and functions.
    Tow
    This will give our drivers a higher average horsepower over what they had before as well as a powerful torque improvement that pulls their engine performance to an improved level with an additional 7 horsepower.
    Regular
    This will help your engine to show its true power using its inherent but hidden horsepower and torque! Enjoy an additional 9 horsepower!
    Premium
    This will give your engine the maximum level of power and torque available! You can enjoy up to 25 horsepower in gains and 30 ft/lb depending on application.
    TUNING FEATURES
    Speed Limiter
    This option allows drivers to set limits that will keep their vehicle under a certain speed or remove the speed limiter.
    Shift Points (Auto Transmission)
    Change the RPM level at which your automatic transmission will shift gears when the throttle is wide open.
    Driving Coach
    The Driving Coach is invaluable for teaching great efficient driving habits. Using momentum and minimizing your acceleration and braking will help your engine access the full mileage available in every gallon of gas that you put in your tank. The Driving Coach uses an efficiency bar to display when you are using your momentum correctly and using a grading system, will develop habits that will benefit your fuel economy. You have the option to use an alert system for when your driving becomes inefficient but of course you can choose to turn off these alerts in the GT T + menu.
    Display
    The GT display is the key to a successful tune. With over fifteen vehicle parameters that can be monitored and displayed, you can watch your engines performance and keep tabs on all the measurements you care about. With one screen displaying 4 gauges at one time, and easy navigation, you will see the difference our tuner can make for your engine from a second to second basis. Multiple display options let you change between gauges and a full color display let you customize your screen to your preference.
    Day and Night Mode
    This feature offers two modes for your GT T+ display. If switching between day and night modes doesn't happen automatically, simply push the bottom button just to the right of the display screen and your background will go turn black, which dims your GT for minimal distraction for night time driving. Pushing the top button to the right of the display screen will make your display go back to a brighter daytime mode.
    DTC's
    Codes used by vehicle manufacturers to identify problems; this information is gathered by the engine computer and accessible through the vehicle's diagnostic port (OBDII).
    Data Logging
    Want to record what your engine performance is doing over a period of time? Use the data logging feature to download results from a drive logged for later use. If you want to record engine performance over a period of time, use this feature.
    Performance Testing
    Someday, you may get the chance to drive where there are no posted speeds. Take your Bully Dog GT T+ with you, because it's a racing man's best friend. Our GT T+ can give drivers a quarter-mile time and a 0-60 time so you can post a personal best. It comes with a drag tree on display so you can really feel what it's like to unleash your engine.
    Safety Warnings
    Pyro Warning
    Your pyro warning will sound when your pyro temperatures become too hot. This can be set up in your GT T+ menu.
    Coolant Temperature
    If your car begins to overheat, you will be the first to know with the use of this warning. This will notify when your coolant temperatures are getting too hot. This is customizable in the GT T+ menu.
    Transmission Temperature
    This gauge option shows the transmission temperature.
    Special Features
    Display and Lighting
    Display Ex Off
    This changes the brightness when canceling the lights for the indicator light of the combination meter, A/C indicator light and clock.
    Display Ex On
    This changes the brightness when dimming the indicator light of the combination meter, A/C indicator light and clock.
    Foot Light
    This sets the time the Outer Foot Light is on.
    Interior Lighting
    This will turn the interior light on when the ignition switch is turned from "ACC" to "LOCK". This will also turn on the interior light, ignition light and step light on when the door is unlocked by the door key cylinder.
    Light Sensitivity
    This adjusts the sensitivity of the lights
    Light Auto OFF
    This will light the headlight for a time after the doors are closed with the ignition switch turned ON and the light control switch is at HEAD or AUTO and the headlight is ON.
    Light Time On This function changes the time between when the doors are closed and the lights go off when the light control switch is at HEAD or AUTO, and the headlight is on.
    Door Lock Functions
    Auto Lock
    Doors on the vehicle lock automatically after the vehicle reaches a certain speed.
    Auto Lock on Shift
    This locks the door when the lever shifts out of the P range.
    Auto Unlock on Shift
    This unlocks the door when the lever is shifted into the P range with the ignition ON.
    Unlock All Doors on Shift
    This unlocks every door but the driver door when the driver door is opened after the ignition is switched off after a certain time.
    Key Cylinder Functions
    Power Windows
    This makes the driver window (and all windows, depending on vehicle grade) and sunroof close if the driver window control is held closed. If the driver door window control is held open, the driver's door window (and all the windows, depending on vehicle grade) and the sunroof will open.
    2 Turns Open All Doors
    This unlocks only the driver door when the key UNLOCK button is pushed twice. When this setting is switched OFF, the key UNLOCK button will unlock all the doors.
    Sunroof Operation
    This will open the sliding roof if the door switch is held to UNLOCK and the ignition switch is OFF. This will also close the sliding roof if the door switch is held to LOCK and the ignition switch is OFF.
    Sunroof Action
    This selects the opening direction of the sliding roof when holding the driver side door key unlocked for a certain time when the ignition switch is OFF.
    Key Fob Functions
    Wireless Control
    This is used to turn the wireless door lock ON or OFF.
    Horn Chirp on Lock
    This turns the wireless buzzer response function ON or OFF.
    Open Door Warning
    If a door is open when vehicle is being locked by the wireless door lock, a buzzer will sound.
    Panic Function
    The "ON" setting will enable the Theft Deterrent System by pressing and holding the Panic Button. Use the Lock Button if the Panic Button is unavailable.
    Wireless Auto Lock
    This automatically locks doors after they are unlocked with the wireless key.
    Auto Lock Time
    This will change the amount of time from unlocking the door(s) with the wireless key to re-locking them automatically.
    Optical Flash on Lock
    This is used to turn ON or OFF the hazard answer back of the wireless door lock.
    Unlock Driver Door
    Use the GT to disable this feature so all of your vehicle doors will unlock with one press of the button on a remote door lock unit.
    Power Back Door
    Wireless PBD Operation
    This function changes the operation of the PBD by transmitter.
    PBD Buzzer
    This function will adjust the volume of the buzzer while the PBD operates.
    Security
    Entry Delay
    This will change the Entry Delay Time, or the period before starting the warning, by the Passive Mode.
    Passive Mode
    This will set the Theft Deterrent System in 30 seconds after the Driver door is closed and the Key is removed from the Ignition Key Cylinder.
    Warning Broken Glass
    This will turn the Glass Break Sensor ON or OFF.
    Warn by Horn
    This turns the glass break sensor ON or OFF. It is only functional when the vehicle has a glass break sensor.
    Warnings
    Key Reminder Sound
    This function changes the times at which the key reminder buzzer will continue to sound.
    Key Reminder Volume
    This changes the volume of the key reminder buzzer.
    Seat Belt Chime
    This changes the seat belt reminder chime.
    Stock photos since I dont have one in hand.
    DISCLAIMER: * Not legal for sale or use in California on pollution-controlled vehicles. CA Offroad Use Only
  2. Sep 7, 2013 at 1:13 PM
    nfs257
    DFW
    She gone
    TAP Auto will have 25 on Monday ready to ship.
  3. Sep 7, 2013 at 1:26 PM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    What about 2005-2008 :pout:
  4. Sep 7, 2013 at 1:37 PM
    nfs257
    DFW
    She gone
    I pulled straight from bully dogs website to err on the side of caution.
  5. Sep 7, 2013 at 1:39 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    +1
    hopefully the GB lasts long enough for the good news to come out for us "older" trucks
  6. Sep 7, 2013 at 1:45 PM
    nfs257
    DFW
    She gone
    As of now there is no end date.
  7. Sep 7, 2013 at 3:21 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    More applications being added weekly... 05-08 guys hang tight!
  8. Sep 7, 2013 at 3:23 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Only supercharged models at this time for the 2013. NA download coming soon.
  9. Sep 7, 2013 at 3:30 PM
    Dierte
    Dierte Member
    Kettering OH
    2013 Taco SR5 DCLB
    Debadged
    That is a hell of a price. Too bad '12-13 na tacos are out for now
  10. Sep 7, 2013 at 4:41 PM
    silverbulet93
    silverbulet93 Member
    Tyler
    Ferndale,WA
    2012 TRD Offroad. Little bit tricked
    LED headlights and fogs, 3" spacer lift 285/65/18 toyo at 2s, Kim's rock stars, urd TCAI, MBRP exhaust, 2 10" Rockford fosgate p3sd4s, every other light replaced with LEDS, blacked out badges
    Hopefully this lasts long enough for them to release it for n/a 12s
  11. Sep 7, 2013 at 11:35 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  12. Sep 8, 2013 at 1:10 AM
    luka
    Kailua, HI
    :cheers:
  13. Sep 8, 2013 at 1:12 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    I had sent you an email on the beta test but nothing back lol so oh well I think I will wait until others test them for me
  14. Sep 8, 2013 at 3:49 AM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    sub'd for info on 05-08
  15. Sep 8, 2013 at 5:14 AM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Subd. been waiting for this moment since 2010. Now have to save monies
  16. Sep 8, 2013 at 5:46 AM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Ordered.....
  17. Sep 8, 2013 at 7:56 AM
    07tacoswb
    07tacoswb Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    Sub'd for the 05-08's too.
  18. Sep 8, 2013 at 8:00 AM
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
  19. Sep 8, 2013 at 8:08 AM
    c2one
    c2one Well-Known Member
    Texas
    '13 Classic Silver SR5 4Runner
    Sub'd for 2013 4Runner
  20. Sep 8, 2013 at 8:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Seems there is a good chance this is a bogus group buy.
Thread Status:
