Bully Dog- GT T+ Tuner (40450) TW Group Buy
Discussion in 'Group Buys' started by nfs257, Sep 7, 2013.
Thread Status:
Not open for further replies.
  1. Sep 13, 2013 at 3:11 PM
    #61
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    I think he is supposed to get it today!
  2. Sep 13, 2013 at 3:35 PM
    #62
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Just sent you a PM Chas. This thing doesn't do half of the things listed that it should do, unless I am missing something....
  3. Sep 13, 2013 at 3:40 PM
    #63
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Reading it now! Will respond asap
  4. Sep 13, 2013 at 4:02 PM
    #64
    sfcadams
    Dan
    Elizabeth, Indiana
    Just as an update to everyone, I am not able to do any of the special features that are advertised with this tuner. I know one or two of them may not apply as I don't have sunroof or a power back door (whatever that is) but nothing listed works...
    Display and Lighting
    Display Ex Off
    This changes the brightness when canceling the lights for the indicator light of the combination meter, A/C indicator light and clock.
    Display Ex On
    This changes the brightness when dimming the indicator light of the combination meter, A/C indicator light and clock.
    Foot Light
    This sets the time the Outer Foot Light is on.
    Interior Lighting
    This will turn the interior light on when the ignition switch is turned from "ACC" to "LOCK". This will also turn on the interior light, ignition light and step light on when the door is unlocked by the door key cylinder.
    Light Sensitivity
    This adjusts the sensitivity of the lights
    Light Auto OFF
    This will light the headlight for a time after the doors are closed with the ignition switch turned ON and the light control switch is at HEAD or AUTO and the headlight is ON.
    Light Time On
    This function changes the time between when the doors are closed and the lights go off when the light control switch is at HEAD or AUTO, and the headlight is on.
    Door Lock Functions
    Auto Lock
    Doors on the vehicle lock automatically after the vehicle reaches a certain speed.
    Auto Lock on Shift
    This locks the door when the lever shifts out of the P range.
    Auto Unlock on Shift
    This unlocks the door when the lever is shifted into the P range with the ignition ON.
    Unlock All Doors on Shift
    This unlocks every door but the driver door when the driver door is opened after the ignition is switched off after a certain time.
    Key Cylinder Functions
    Power Windows
    This makes the driver window (and all windows, depending on vehicle grade) and sunroof close if the driver window control is held closed. If the driver door window control is held open, the driver's door window (and all the windows, depending on vehicle grade) and the sunroof will open.
    2 Turns Open All Doors
    This unlocks only the driver door when the key UNLOCK button is pushed twice. When this setting is switched OFF, the key UNLOCK button will unlock all the doors.
    Sunroof Operation
    This will open the sliding roof if the door switch is held to UNLOCK and the ignition switch is OFF. This will also close the sliding roof if the door switch is held to LOCK and the ignition switch is OFF.
    Sunroof Action
    This selects the opening direction of the sliding roof when holding the driver side door key unlocked for a certain time when the ignition switch is OFF.
    Key Fob Functions
    Wireless Control
    This is used to turn the wireless door lock ON or OFF.
    Horn Chirp on Lock
    This turns the wireless buzzer response function ON or OFF.
    Open Door Warning
    If a door is open when vehicle is being locked by the wireless door lock, a buzzer will sound.
    Panic Function
    The "ON" setting will enable the Theft Deterrent System by pressing and holding the Panic Button. Use the Lock Button if the Panic Button is unavailable.
    Wireless Auto Lock
    This automatically locks doors after they are unlocked with the wireless key.
    Auto Lock Time
    This will change the amount of time from unlocking the door(s) with the wireless key to re-locking them automatically.
    Optical Flash on Lock
    This is used to turn ON or OFF the hazard answer back of the wireless door lock.
    Unlock Driver Door
    Use the GT to disable this feature so all of your vehicle doors will unlock with one press of the button on a remote door lock unit.
    Power Back Door
    Wireless PBD Operation
    This function changes the operation of the PBD by transmitter.
    PBD Buzzer
    This function will adjust the volume of the buzzer while the PBD operates.
    Security
    Entry Delay
    This will change the Entry Delay Time, or the period before starting the warning, by the Passive Mode.
    Passive Mode
    This will set the Theft Deterrent System in 30 seconds after the Driver door is closed and the Key is removed from the Ignition Key Cylinder.
    Warning Broken Glass
    This will turn the Glass Break Sensor ON or OFF.
    Warn by Horn
    This turns the glass break sensor ON or OFF. It is only functional when the vehicle has a glass break sensor.
  5. Sep 13, 2013 at 4:38 PM
    #65
    sfcadams
    Dan
    Elizabeth, Indiana
    Update...
    Spoke to Chas (I am sure he will chime in here soon) and will unfortunately be returning my tuner. I mainly bought it for all of the bells and whistles that I listed above and unfortunately, it will not perform those options (at least not on my 2011 Tacoma DCSB, fully loaded). Chas said he will be getting me an RA number on Monday so I can get it headed back to them.
  6. Sep 13, 2013 at 5:13 PM
    #66
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Dam that sucks. I'm having seconds thoughts about buying this tuner now....
    I hope other users can chime in on their experiences.
  7. Sep 13, 2013 at 5:15 PM
    #67
    nfs257
    nfs257 [OP] Well-Known Member
    DFW
    She gone
  8. Sep 13, 2013 at 5:18 PM
    #68
    WhiteBaja
    WhiteBaja Member
    Texas
    2013 Baja
    Does it work on 2013 na engine?
  9. Sep 13, 2013 at 5:20 PM
    #69
    Lord Helmet
    Nick
    '24 X3 M40i
  10. Sep 13, 2013 at 5:27 PM
    #70
    sfcadams
    Dan
    Elizabeth, Indiana
  11. Sep 13, 2013 at 5:38 PM
    #71
    nfs257
    DFW
    She gone
    :confused: hopefully its a typo...
  12. Sep 13, 2013 at 5:44 PM
    #72
    sfcadams
    Dan
    Elizabeth, Indiana
    I just hope I don't get screwed with a restocking fee or anything like that. I shouldn't given the fact the product doesn't do everything they state it will do...
  13. Sep 13, 2013 at 5:50 PM
    #73
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    It may be a dumb question, but do you guys really think this will allow me to turn my very much so hated speed limiter (115mph) high enough that it is practically off? And do you think I could also change my auto's shift points to a few hundred rpm higher so i didn't have to manually shift it at the top of each gear at wide open throttle? From what i've read, it sounds like these options are available. i want to know that someone has done it with out issue before i throw down the cash. Adjusting those two things would make me never give up my tacoma.
  14. Sep 13, 2013 at 5:51 PM
    #74
    nfs257
    DFW
    She gone
    Can't touch speed limited per the link above. And not sure on shift points...
  15. Sep 13, 2013 at 6:00 PM
    #75
    AR15xAR10
    Damn, as I said, those are my two biggest quarrels about tacomas. Roll racing is fun until you get to 115 and the other person walks away from you because they have a higher set limit or none at all. who am i kidding, MY tires are only rated for 112mph anyway. Thank you for the quick reply.
  16. Sep 16, 2013 at 2:02 PM
    #76
    sfcadams
    Dan
    Elizabeth, Indiana
    Still waiting on a RMA number to return this thing...
  17. Sep 16, 2013 at 6:32 PM
    #77
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    We are too. I havent forgotten about you, but I just was able to put in the request this morning.
    No restock fee thru TAP Auto Parts - we have you covered.
  18. Sep 16, 2013 at 6:41 PM
    #78
    sfcadams
    Dan
    Elizabeth, Indiana
    Ok Chas, thanks...
  19. Sep 29, 2013 at 7:08 AM
    #79
    fla taco
    fla taco Well-Known Member
    Central Florida
    05 Dblcab TRD OR
    sub'd for 05-08 as well.......:cool:
  20. Nov 5, 2013 at 8:16 PM
    #80
    samuelprz
    samuelprz Well-Known Member
    Sam
    NoR CaL Modesto / Fresno
    06 PreRunner TRD Off-Road,
    New 2006 Taco (red) 8112 Front Bilstein Shocks Maxtrac Spindles Fox2.0 With Resis Rear All Pro Expo Leafpack RRW 18 Wheels w/ Toyo RT 33x12.50r18 LED Headlights Pioneer AVH 4201NEX Hybrid Audio Unity and Mirus ARC Audio 300.4 RIP 2006 Taco (silver)... you will be missed Eibach Coils Bilstein 5100s front Maxtrac Spindles SpiderTrax Wheel Spacers Bilstein 5100s rear*extended All Pro Expo Leafpack 6,000k HID's (Headlights and Fogs)
    Sub'd for the 05-08 as well ..... hopefully sometime soon.....
Thread Status:
