Bully dog tuner bricked my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylanmclean, Jan 12, 2020.
  1. Jan 12, 2020 at 8:51 PM
    Dylanmclean
    Dylanmclean [OP] Active Member
    Dylan
    Red 2005 tacoma
    I got a bully dog tuner for my truck and I installed it a few days ago while the customer support was still open and all was good and it all worked. Today I was playing with it and I tried doing a abs calibration just because. The tuner didnt say anything about waiting until customer support was open to do this (it did for a few other things) the calibration wasnt working at all it was just stuck in a loading screen I waited about 2 hours with it like that, it didnt work so I took the key out, started the truck again and all was good until later when I went to move my truck and I went 15 feet before it completely shut my truck off and it wont turn back on wont even crank. I have no idea what to do... I have work in the morning.
    Grumpy likes this.
  2. Jan 12, 2020 at 8:55 PM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    No uber or any ride sharing service in Vancouver...
  3. Jan 12, 2020 at 8:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you tried disconnecting the battery for about 15 mins?
    hazard2600 and grubburg like this.
  4. Jan 12, 2020 at 8:58 PM
    tcjacado
    tcjacado Well-Known Member
  5. Jan 12, 2020 at 9:00 PM
    Grumpy
    Grumpy My 1st Tacoma
    Maurice
    Oahu, Hawaii
    14/DCLB/V6/4x4/SR5
    17" Method Grid Titanium rims w/ Pro Comp Sport A/T 265/70/17 tires, Mobtown Offroad ribbed Tailgate skin, installed LED lights in painted rear bumper black, faux TRD grill, color match grill surround. LEDs in map, license plate, center console, and dome lights. Anytime driving lite mod, debadged, vent visors, AA Maglite mounted under center console armrest. Antitheft hose clamp on tailgate, LED bed lighting kit. LED spot lights in lower front bumper. Weathertech floor mats. Painted various interior parts black, homemade 7 pin relocation bracket, Valet under door LEDS, CMC, SPC UCA, Bilstein 5100, OME 885, Headstrong AAL. Pop&Lock.
    ummmm..... :notsure: vacation day tomorrow while you get Bully Dog customer service on the horn.
    Gunshot-6A, 420taco, whatstcp and 2 others like this.
  6. Jan 12, 2020 at 9:01 PM
    tcjacado
    Was the calibration off/ not working on the abs? Did it need to be calibrated?
  7. Jan 12, 2020 at 9:06 PM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    It did not need to be calibrated. I was just messing around with it.
  8. Jan 12, 2020 at 9:08 PM
    tcjacado
    Lawfarin, Naveronski, Hobbs and 22 others like this.
  9. Jan 12, 2020 at 9:13 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Did the truck even NEED a tuner in it?..
    yikes.
    good luck.
    Naveronski, magneticwhite88 and Mully like this.
  10. Jan 12, 2020 at 9:29 PM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    No it didnt... my buddy owed me money and he knew I wanted a tuner of some sort and he had this one lying around so he gave to to me and then this happened.
  11. Jan 12, 2020 at 9:30 PM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    It sounds like this tuner is garbage when I get this dealt with I'm gonna try and just return it.
    Bridge4 and DG92071 like this.
  12. Jan 12, 2020 at 9:30 PM
    tcjacado
    Hobbs, Markcal, Mully and 5 others like this.
  13. Jan 12, 2020 at 9:49 PM
    RyanTacoMC
    RyanTacoMC 96 Tacoma LX (RIP)
    Bay Area, CA
    2005 Base Access Cab 5-Lug RWD Manual
    4x4 Springs, QA1 TS703s, Rear Sway Bar, blah blah
    I didn't think you could "brick" a non-electric vehicle... It's amazing how many electronic/computer problems I solve for people by "re-booting." Which is often just turning things on and off. Might want to try this.
    Gunshot-6A and DG92071 like this.
  14. Jan 13, 2020 at 6:04 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Does the buddy own a Ford truck?:anonymous:
    SR-71A, 2WD and goforbroke123 like this.
  15. Jan 13, 2020 at 6:12 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  16. Jan 13, 2020 at 7:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Probably going to be looking under the glove box for the number on the ECU, then order a used one off of eBay. Most likely scenario.
  17. Jan 13, 2020 at 7:07 AM
    DG92071
    DG92071 Well-Known Member
    Oh that sucks...
    What a crap situation to be in.
  18. Jan 13, 2020 at 7:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A few guys using the HP Tuners had done that. Connection failed or battery voltage too low, during a flash, and bricked. Then the software was updated by HP Tuners, and alleviated the situation.
    DG92071 likes this.
  19. Jan 13, 2020 at 7:10 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  20. Jan 14, 2020 at 8:29 AM
    Dylanmclean
    Dylan
    Red 2005 tacoma
    Just ordered a
    Yep that's what is happening.
    Just ordered a used ecu from a wrecked truck that was tested working.
    Torspd[QUOTED] likes this.
