Bump After Stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by safaristeve, Oct 18, 2016.
  1. Oct 18, 2016 at 12:14 PM
    safaristeve
    safaristeve [OP] Member
    2016 Access Cab TRD Sport
    My 2016 Tacoma (2/2016 build date with 2,800 miles on it) has recently developed an issue with a "bump" approximately 1-2 seconds after coming to a complete stop. It feels like it's under the floorboard and I can feel it in the steering wheel. It's at the dealer now and they said they swapped the driveshaft yesterday, but haven't solved it.
    I see something similar regarding prior generations, but has anyone had this issue with a 2016/17?
    wilcam47 likes this.
  2. Oct 18, 2016 at 1:07 PM
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    Sounds like WHEN ACCELERATING FROM A STOP OR COMING TO A STOP, A SENSATION OF BEING BUMPED FROM BEHIND OR FROM THE REAR VEHICLE, A CLUNK OR THUNK NOISE AND TO REDUCE CONDITION, IMPROVEMENTS ARE IMPLEMENTED ON REAR PROPELLER SHAFT that's the problem I had on my 4Runner.
    Replaced driveshaft under tsb.
  3. Oct 18, 2016 at 1:46 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    ...how I felt reading this post....
    C41n, ktbell444, BadCow and 37 others like this.
  4. Oct 18, 2016 at 1:58 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    I have had this same sound/feel show up here lately. I have about 5500 miles on mine. Also had a strange buzzing/humming noise today while a/c was on high. Always some kind of new issue with this truck. I am tired of going to the dealer to get problems looked at. One of these days I may be visiting a GM or Ford dealer soon to rid myself of all the problems. I am 40 y/o and have owned at least 16 brand new trucks over the years. Most of them were Fords. This one Tacoma has had more problems and days in the shop than all other vehicles combined. It's not even 6 months old yet.
  5. Oct 18, 2016 at 1:58 PM
    4RNR
    4RNR トヨタ
    Ge
    America
    2016 Tundra crewmax
    Sorry that was copy and paste from TSB
    C41n, musher and Benzdriver81 like this.
  6. Oct 18, 2016 at 2:00 PM
    4RNR
    4RNR トヨタ
    Ge
    America
    2016 Tundra crewmax
    Toyota likes to scream on their work orders.
  7. Oct 18, 2016 at 2:17 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    remember looking into drive line "lash" about 4 months ago. read good things about motorcraft xg8a since i knew superduties were prone to similar driveshaft lash. have a small tube of it, just havent bothered pulling driveshaft yet. think its a fairly well known fix for lash
  8. Oct 22, 2016 at 9:38 PM
    BOZOJUICE
    BOZOJUICE Well-Known Member
    2023 ICE CAP PRO
    I was having this problem as described. After reading this I greased the Zerk fittings on the rear drive shaft and I must say at this point after a few days problems is no longer.
  9. Oct 22, 2016 at 9:52 PM
    Rockdaground
    Rockdaground Well-Known Member
    2017 blue Tacoma off road LB
    Stock
    I have felt this bump you speak of on my 2017. It happens when I'm coming to a complete stop after long trips. It even slightly pushes the truck while stopping. I always thought it was normal. I think it's just the drivetrain taking up slack when the transmission down shifts when slowing down. I have a 2008 VW that has always done this since I bought it new. I took it a couple times to the dealer and I was told it's normal operation. It now has over 100,000 miles with no problems.
    Ed Crankshaft likes this.
  10. Oct 22, 2016 at 10:19 PM
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    You might have the same issue as me and @Sndtrper. We both been in contact about having the issue of the truck clunking and lurching forward when coming to a stop usually around the 8 to 15mph mark. Notice it especially when cold. Haven't had a chance to visit the dealer but will next week. Haven't seen too many members post about them having this issue.
    mauidogg likes this.
  11. Oct 22, 2016 at 10:42 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    Sounds like the same issue i'm having, also noticed when im coming to a stop but dont fully stop and give it some gas, it feels like im driving a manual and let go of the clutch really fast and drops it to gear
  12. Oct 23, 2016 at 8:58 AM
    safaristeve
    The dealer gave the truck back after five days (and per the service advisor, 20 hours of work) and said it's the fuel sloshing around in the tank. I have my doubts being that I didn't notice it until a couple of weeks ago, but I have to wait until this 3/4 tank is used to see.
  13. Oct 23, 2016 at 1:14 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    4th generation 4Runners had the same problem. On that platform all it took was pumping grease into the slip yoke zerk until the pressure from the grease just barely started to make the slip joint move.
    It was an easy fix which is why I'm still dumbfounded that Toyota didn't put a zerk at the slip joint.
    Clay7160 likes this.
  14. Oct 23, 2016 at 1:43 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I had the same problem. Everyone said axle wrap. Had the truck looked at by a field rep, greased with Motorcraft grease, checked axle wrap with a go pro, and finally had the driveshaft replaced. Nothing worked. The only thing that finally fixed it was drilling a hole in the slip joint area of the DS. A very small hole, just enough to allow the pressure to equalize. Some trucks do it and done don't.....I was unlucky. I know the fix sounds crazy, but it's legit. What you're feeling is the slip joint overcoming air pressure and releasing. This "fix" was authorized by the Toyota field rep. They were trying this out and I let them do it as long as they'd replace the DS if water/dirt intrusion screwed up the slip yoke. They agreed of course.
    9TRDTCO likes this.
  15. Oct 24, 2016 at 12:53 AM
    9TRDTCO
    Any way you can provide me a copy of the service record of the fix?? Ive been at the dealership countless times about this issue. Ive always thought it was my transmission.
  16. May 8, 2017 at 10:12 AM
    wdelarme
    wdelarme Active Member
    You have any pictures of where they put the hole?
  17. May 8, 2017 at 1:20 PM
    89hatcher
    89hatcher Well-Known Member
    i have this same thud when coming to a spot once in a while. brought it to the dealer and they could not replicate the thud.
  18. May 8, 2017 at 1:23 PM
    StORmTrooperLV
    StORmTrooperLV Well-Known Member
    Stephen
    Las Vegas
    2016 SuperWhite Tacoma DC Off Road
    RCI Front Skid
    I had similar incident in my 2016. I read that it may be fuel, and I am able to recreate the incident when I have a 3/4-full tank of gas. If I am low, don't feel it. So I did my own diagnosis that it is the fuel. I didn't notice it until about 2-3 months of ownership.
    Joe23 likes this.
  19. May 8, 2017 at 1:49 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    interesting.
    I get a thump after stopping about a second after as well. but I was told it's just fuel sloshing around.
    Only happens when the tank is between half and 3/4
  20. May 8, 2017 at 1:54 PM
    JFick
    JFick Sawzall Enthusiast
    Los Angeles
    ‘19 TRDOR 6MT, ‘11 BMW M3 DCT
    Softopper 255/85r16 Yokohama MTs Camburg UCAs King extended travel coilovers King extended travel rear shocks Firestone airbags OME medium duty leafs
    My dad's Tundra and my Tacoma both have this problem. It only happens every once in a while, but it is definitely an odd occurrence.
