Bump-Starts and runs great, won't start with key - P0335 - ECU replacement fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hyharari, Oct 21, 2024.
  1. Oct 27, 2024 at 7:08 PM
    #121
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea I would love to see Ivan diagnose this and do a video, this is definitely the weirdest case study of the year.
    winkel and TnShooter[QUOTED] like this.
  2. Oct 27, 2024 at 8:19 PM
    #122
    Yossarian
    Yossarian Well-Known Member
    Arizona
    2023 4Runner SR5P 4x4 / 1996 3.4L 4x4 AC
    Diode Dynamics fogs, HIR reverse light, Hefty Fab sliders, Wet Okole seat covers / Fabtech coilovers, 33" KO2s, Hella 500FFs, Hella ECE headlights, tube bumper, sliders
    You guys are doing great work, wish I had more to contribute
    Stevie17 and winkel like this.
  3. Oct 28, 2024 at 3:51 PM
    #123
    isdjww
    isdjww Well-Known Member
    Pinewood Springs, CO
    2014 Tacoma, 4.0L, 6-sp manual
    I don't think l'm looking at the EFI relay. The wiring diagram is shown on pg 3 of this thread.
    The ECM has power from two other feeds and the power from the ER relay feeds the +B terminal of the ECM, like the ECM is verifying that the relay closed when the ECM closes the relay.
  4. Oct 28, 2024 at 4:13 PM
    #124
    isdjww
    The reason I'm asking about the ER relay is I'm looking for a logic reason not to start. In the old days, Ford had a relay under the dash that would trip if you were in an accident shutting off the fuel pump (you manually reset it by pressing a button on the relay). Did Toyota implement something similar to that, that would keep the engine from starting? Something like lack of power to the SRS system?
  5. Oct 28, 2024 at 4:21 PM
    #125
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Interesting thought, but wouldn't that also affect it during the bump/clutch pop while rolling, start?
  6. Oct 28, 2024 at 4:25 PM
    #126
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There aren't but 3 relays for the 2TR?
    At least on my diagrams that is all I see?
  7. Oct 28, 2024 at 4:27 PM
    #127
    TnShooter
    Deogee
    STOCK
    Yeah that switch was the inertia switch.
    Had one go bad once on a Ford Ranger.
  8. Oct 28, 2024 at 5:06 PM
    #128
    hyharari
    hyharari [OP] CH
    CH
    2007 Manual Transmission Access Cab 4WD, 2.7L
    So I did my best and here's a little summary in visual, all passed the tests (highlighted green):
    Circles indicate what I didn't manage to back-probe.
    E8 Pin 9 is hard to get to amongst all the wires.
    I just couldn't for the life of me get the probe inside E4 pin 17 (Coil control, I guess thick cable), just too tight.
    Any idea of another easier place to test?
    The E8 Pin 29 (highlighted orange) is empty on my model, maybe a typo or a mix-up?
    I looked up the wiring diagrams and didn't see it there either.
    Here's a pic:
    Attached are the wave files, but I don't see anything interesting...
  9. Oct 28, 2024 at 5:12 PM
    #129
    TnShooter
    Deogee
    STOCK
    Well it looks like E8 - 29 failed.
    I'd start with making sure it is "bad".
    Unplug it. Use a test light on it. If it doesn't light up, then we need FIX IT and........:fingerscrossed:
  10. Oct 28, 2024 at 5:22 PM
    #130
    hyharari
    hyharari [OP] CH
    CH
    It didn't fail, it just doesn't exist. Sorry maybe highlighting was misleading, see picture and post closely. Here's the E8 Pinout:
    TnShooter[QUOTED] likes this.
  11. Oct 28, 2024 at 5:36 PM
    #131
    TnShooter
    Deogee
    STOCK
    Interesting.
    It shows it on the diagrams.
    Let me see what it is for.....
  12. Oct 28, 2024 at 5:41 PM
    #132
    TnShooter
    Deogee
    STOCK
  13. Oct 28, 2024 at 5:52 PM
    #133
    TnShooter
    Deogee
    STOCK
    wonder if the J14 connector has the wire in there?
    If so, I'd say you "need" it.
  14. Oct 28, 2024 at 5:55 PM
    #134
    TnShooter
    Deogee
    STOCK
  15. Oct 28, 2024 at 5:56 PM
    #135
    TnShooter
    Deogee
    STOCK
  16. Oct 28, 2024 at 5:56 PM
    #136
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Looks like no e8 29 on my 2009 2TR
    TnShooter and hyharari[OP] like this.
  17. Oct 28, 2024 at 6:30 PM
    #137
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'll try and give it a look tomorrow and post back.
  18. Oct 28, 2024 at 6:30 PM
    #138
    TnShooter
    Deogee
    STOCK
    Thank you Sir!
    Just what we needed.
  19. Oct 28, 2024 at 6:45 PM
    #139
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That is the EFI relay (maybe it looks like ER on the black/white schematic drawing), that is a power feed to the ECM. If it was missing we would have no communication.
    05-11 models had a dedicated "crash detected" line from the SRS module to the ECM to signal fuel shutoff in the event of a crash, ignition cycle resets it. 12-15 models it just sends a message over the CAN bus.
  20. Oct 28, 2024 at 6:56 PM
    #140
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Powers and grounds look good, we have no injector control which makes sense since RPM is 0.
    What are you using to backprobe? I did mine pretty easily but I have some relatively small backprobes.
    It's odd E8-29 shows to be populated on 07 and 08 but 06 and 09 it doesn't so not sure, if it's blank then it's not needed though.
