Bump steer fixes?
Discussion in 'Archive Garage' started by Hami0528, Dec 7, 2023.
  1. Dec 7, 2023 at 4:36 PM
    Hami0528
    Hami0528 [OP] Well-Known Member
    Brayden
    Tulsa, Oklahoma
    2011 Timberland Mica Tacoma TRD Off Road
    Dobinson IMS shocks and coils, SPC upper control arms. Archive garage rear shock relocation kit with king 2.5x12 smoothies with adjusters and archive medium duty leaf pack.
    Just wondering if there’s a fix for bump steer with a lift. I have dobinson ims front shocks set at about 2.5 inches and spc control arms. Alignment could be part of the problem because I know alignment shops will align according to oem specs and mine is not. Just wondering if there was any tie rod modifications out there to fix it or a rack and pinion drop etc..
  2. Dec 7, 2023 at 6:16 PM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Hey Braden,
    Being a 2011, my 1st thought is make sure everything is in good condition like lca rubber bushings, and also the steering rack mounting bushings can be replaced with Energy suspension poly bushings. I know my 2005 rack bushings are bad.
    Eric
    Hami0528[OP] likes this.
  3. Dec 7, 2023 at 7:47 PM
    Hami0528
    Brayden
    Tulsa, Oklahoma
    Thanks I’ll have to check my bushings when I get the chance. I do know my inner tie rod on one side is going bad and a shop said my lca bolt is seized so I may start there and then try and get a fresh alignment. Would the alignment specs be a little different on a lifted truck? I kinda already know the answer is yes but I just don’t know how to tell a shop to compensate for the lift as far as what camber, caster etc. numbers to go for. Like I said though the bump steer isn’t that bad at all most the time but it does get a little annoying sometimes. Thanks for the response though.
