bump steer,loose feel in steering 2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bg Buck, Jun 8, 2012.
  1. Jun 8, 2012 at 7:21 AM
    Bg Buck
    Bg Buck [OP] Member
    mn
    12 sr5
    I have a 12 dcsb 4x4 steering has always felt not quite right, lots of bump steer,feels loose. Truck is stock, except 265/75\16 duratracs on MB tko wheels. Read alot about positive caster will that help with stock suspension?
  2. Jun 8, 2012 at 8:46 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    First thing to do is take it to the dealer for an alignment, especially since it's under warranty. If they say it's normal then ask to test another one. It could be that it's simply not up to your expectation. These trucks are a little loose.
  3. Jun 8, 2012 at 3:55 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    My truck felt like this the moment I bought it. The dealership claims it to be normal. I took a few more Tacomas out for test drives and they did feel the same, especially on gravel roads.
  4. Jun 8, 2012 at 6:05 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    Same here and the dealer told me the same thing.
  5. Jun 8, 2012 at 6:28 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Mine doesn't feel like that...I have a sport. What do you have? I think the sport is the tightest because they set it up for the road.
  6. Jun 8, 2012 at 11:07 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Maybe if you compare to a car, otherwise I have to disagree with you 100%. Not trying to argue for the sake of an argument, it's just my opinion based on experience that the these trucks handle much better than average for pickups.
    OP, make sure your tires aren't overinflated. Too often someone will inflate to the tires max rated pressure, where you should have around 30 front and 28 rear for your tires.
    And check the rear suspension for loose ubolts.
  7. Jun 9, 2012 at 7:47 AM
    Bg Buck
    Bg Buck [OP] Member
    mn
    12 sr5
    Mine is just a SR5 4x4. I came from a 07 chev 2500hd which was way tighter steering than this. Plus the suspension was way stiffer on it also.
  8. Jun 9, 2012 at 7:48 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    The sport is a trim package. You have the same suspension as the Trd OR
  9. Jun 9, 2012 at 8:05 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Mine is lifted with coilovers cranked to about 2-1/2" so the rough ride pulls the truck a little when going over bumps, making it feel like bumpsteer. I think that is more because the digressive nature of the coilover and larger tires.
    Around corners though my truck handles really well for a truck. Especially a lifted one. I replaced the sway bar bushings with polys and that helped a lot. I would imagine this is where bumpsteer is most noticeable, when you corner and hit a bump.
  10. Jun 9, 2012 at 8:16 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Different front springs and larger wheels with lower profile tires. It will handle better on the road.
    OP, you could also try this:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/88077-steering-column-fix.html
  11. Jun 9, 2012 at 8:51 AM
    greenrustic
    NY
    Also have 4 leaf springs in the rear out of the factory as opposed to the OR that has 3. It seems that some sr5's have 4 some have 3. I've heard though I can not confirm that the sport has a heavier sway bar.
  12. Jun 9, 2012 at 1:12 PM
    05Moose
    Jim
    I believe it's only Canadian trucks that have 4 leafs. US trucks get 3. Not sure on the sway bar. In past discussions, it was only the springs (OR has progressive, SR5 and Sport have linear springs).
  13. Jun 9, 2012 at 1:20 PM
    06ryan27
    06ryan27 Well-Known Member
    Aiken, SC
    12 DBL 4x4 SPORT
    3" RBP lift, anytime fogs
    US Sports do get 4 leafs, it does have different coils and it does have a larger diameter sway bar
  14. Jun 9, 2012 at 1:22 PM
    seric007
    seric007 Well-Known Member
    this is going to sound like a joke, but you need to insert a ziptie on the steering shaft. there's a thread on it. works like a charm. dealer is just a waste of time for this one.
  15. Jun 9, 2012 at 1:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are correct, It does sound like a joke...
    Please explain? Where on the steering shaft and What would a zip tie do on the steering shaft. :p
    Mine drives and steers better than most cars. If you want to feel some shitty steering drive a ford. Esp a Mustang.
  16. Jun 9, 2012 at 4:11 PM
    Bg Buck
    Bg Buck [OP] Member
    mn
    12 sr5
    Mine has 4 leafs. Also I just did the zip tie mod. Seems to take some loose feel out of the steering.
  17. Jun 9, 2012 at 4:17 PM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
  18. Jun 9, 2012 at 4:22 PM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    The sport and offroad have different coils, don't they? Progressive vs linear.
    Never mind, didn't make it that far down
  19. Jun 9, 2012 at 5:01 PM
    Rosesplus
    Rosesplus Well-Known Member
  20. Jun 9, 2012 at 7:44 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    So just stiffening up the flex coupling. I see now. I must be lucky. I don't have any of the issues listed on the site.
