Bump Steer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco9486, Sep 15, 2023.
  1. Oct 20, 2023 at 4:21 PM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    Interesting. I have a similar setup. Doesn't really pull. Some folks record and upload to YouTube and then post.
  2. Oct 20, 2023 at 4:23 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Have you checked your tire pressure?
    I remember one of the shops I went to for an alignment inflated the tires a bit more to my liking and had annoying bump steer. The alignment specs came out good, so I let some air out all around and noticed an improvement. The 10-ply thicccness magnified it lol
    BlueTaco9486[OP] likes this.
  3. Oct 20, 2023 at 4:50 PM
    BlueTaco9486
    BlueTaco9486 [OP] Well-Known Member
    Bunk
    2013 Blue Taco
    Factory Off Road Package
    I’ll go check tire pressure now. And tomorrow during the daylight, i will record the movement on the steering wheel and post it here. It’s just that anytime. I ride down a gravel road or grassy road or even in a parking lot with any type of rough terrain the steering wheel pulls left and right with the suspension.
  4. Oct 20, 2023 at 5:05 PM
    BlueTaco9486
    Bunk
    2013 Blue Taco
    Tire pressure was fine. 32-33 psi. I don’t believe that it would cause as dramatic as a pole to the left and right my steering wheel is experiencing though. Especially for how long it’s been happening.
    Island Cruiser likes this.
  5. Oct 20, 2023 at 9:19 PM
    Island Cruiser
    Kauai
    Baja
    Mine was a ridiculous 38 lol. It was reacting to every little dip on the road. At least you ruled that out and hope you found the problem soon!
  6. Oct 21, 2023 at 2:33 AM
    BlueTaco9486
    Bunk
    2013 Blue Taco
    Thank you, I’ll post updates.
    eteran810 and Island Cruiser like this.
  7. Mar 25, 2024 at 6:58 AM
    eteran810
    eteran810 Active Member
    2014 Toyota Tacoma PreRunner RWD
    Having very similar problems as you. I have new LCA, front struts, UCA, steering column shaft and I’m still bump steer. Did you figure out your issue. I’m at the point of wanting to change out my rack and pinion.
