Bump Stop Install Question
Discussion in 'Suspension' started by DrFunk, Mar 2, 2023.
  1. Mar 2, 2023 at 7:48 AM
    DrFunk
    DrFunk [OP] New Member
    Montana
    2004 Jade Green Tacoma Ext. Cab SR5 V6
    Hey TW, long time reader, first time writer.
    I'm installing my Dakars today but the OEM bump stops won't arrive for a week or two. I'm wondering if I need to lift the truck and drop the axle to take off my U bolts and install the bump stops when they arrive? In other words, could I loosen the U bolts while the truck is weighting the leaf spring pack on the perch safely?
    Or will I need to put the truck on jack stands and drop the axle to unweight the leaf spring pack, remove suspension, etc etc. ?
    Thanks so much for your help.
  2. Mar 2, 2023 at 7:52 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    You should be able to leave the truck on the ground, loosen the u-bolts on one side, slide in the bump stop, then tighten it up, and do the other side. I'd only do one side at a time.
    whatstcp likes this.
  3. Mar 2, 2023 at 8:14 AM
    DrFunk
    Montana
    Excellent, thank you so much for your prompt reply. Cheers.
    Crikeymike likes this.
