Bump Stop question
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, May 14, 2013.
  1. May 14, 2013 at 11:43 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im looking for some new rear bump stops. Currently running stock leafs with an AAL.
    Will the Daystar stops work with or replace the stock center pin for the leafs?
    http://store.sdhqoffroad.com/daystar.aspx
  2. May 14, 2013 at 12:16 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Or do they mount on the frame above the leafs?
  3. May 14, 2013 at 1:41 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I think they mount from above
  4. May 14, 2013 at 1:48 PM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    you can use the wheelers off road super bumps that are on the 2nd gen page on the rears, they fit just fine. I put them on my truck and they work great. I have the 2nd gen front super bumps also but have not put them on yet.
  5. May 14, 2013 at 3:39 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Bmack, can you snap and post some pics when you have a chance? Thanks guys that helps a lot (Ive been all over the '04 Tacoma section of wheelers and couldn't find any bump stops).
