bump stop question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki, Jul 27, 2020.
  1. Jul 27, 2020 at 3:03 PM
    kiki
    kiki [OP] Active Member
    florida
    2019 tacoma 2.7L SR 4 door.
    if i raise my front end 2" inches higher, how much do i have to extend both (front end) bump stops? so shocks dont bottom out....???
  2. Jul 27, 2020 at 4:46 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    How are you lifting front?
  3. Jul 27, 2020 at 4:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you're using lift springs or Bilstein 5100s, you don't have to touch the bump stops.
    If you're lifting with top hat spacers, the bumpstop should be extended by roughly the same thickness as the spacer. e.g. to get a 2" lift, typically the spacer would be about 1.2" thick, so the bumpstop should be extended by 1.2" as well.
    71tattooguy likes this.
  4. Jul 27, 2020 at 4:57 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Exactly Thank you
  5. Jul 27, 2020 at 5:00 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Get 5100’s or Eibach great kits period. Been down that spacer road never again. Just my 2cents. Good luck
  6. Jul 28, 2020 at 2:40 AM
    kiki
    florida
    ok...so if i use new strut assembly, fox, bilstein, etc...i dont have to extend bump stop! but if i use strut spacers on top i do? is it becuase new strut assemblies are designed to go lower and not bottom out? were adding a spacer would push original shocks past there stop point? is that why?
