Bump stop questions
Discussion in 'Suspension' started by CorpsmanUp, Jul 23, 2017.
  1. Jul 23, 2017 at 8:26 AM
    CorpsmanUp
    CorpsmanUp [OP] Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    Howdy all,
    How are bump stops supposed to be measured for?
    Currently running Pro Comp stage 2 (has full Coilovers not spacers) 6in lift with DB and waiting on my kings to arrive for the C/O replacement. When the kit was installed almost 40k miles ago it was also installed with aftermarket drop brackets for bump stops however theres only about an inch in between the bump stops and LCAs on the front and did a chalk test the other day just driving to and from work and I'm hitting the bump stops on normal in town and highway driving.
    Is this normal? How would someone determine the how much space between UCA and bump stop for optimum wheeling and driving conditions?
    smw62891 likes this.
  2. Sep 10, 2017 at 12:00 AM
    smw62891
    smw62891 Well-Known Member
    Stephen
    Santa Fe, NM
    09 Tacoma DCSB
    Bump for info as well. My fabtech is exactly the same way. Looks to be literally an inch of movement allowed before hitting bumps on the front.
  3. Sep 10, 2017 at 12:15 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Only way to really do it right is to cycle the suspension.
    But on the IFS front, if you have about an inch between the bumpstop and the LCA, you should have around 2" of bump travel at the wheel.
    CorpsmanUp[OP] and THROTTLE231 like this.
  4. Sep 12, 2017 at 3:12 PM
    CorpsmanUp
    Gibby
    Suffolk, VA
    Would you advise cycling front suspension without coilovers? Or with coilovers still on?
  5. Sep 12, 2017 at 6:11 PM
    bullaculla
    Da big big island!
    You need the coilovers in, otherwise how you gonna know where the bump stop should be? You want your bumpstop to stop the travel before your shock bottoms out. Even harder if you have soft bumpstops like superbumps. Those things will pancake super flat on hard hits.
    You need to take off the coil and let out the nitrogen pressure out of the shock, then cycle it. Yes it's a pain in the ass, but it's the right way to get full travel with properly set up bumps. I've cycled mine lots of time during my swap, and need to do it a couple more times...
    https://www.tacomaworld.com/threads...-build-pic-heavy.293408/page-64#post-15093857
