Bump stop spacer. To keep shock from bottoming out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Aug 10, 2011.
  1. Aug 10, 2011 at 7:44 AM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Are there such things as bump stop spacers to extend the bump stops a bit? DSM and I are in the middle of finding a rear shock that would be the right length for my 2" lift. The small 5100's are too small, and the large 5100's(the ones that are on now) are barely too big. The shock gets fully compressed before the bump stop hits frame. I need a temporary fix. I've heard a few on here say something about bump stop spacers, but I can't find anything on them.
    Here's a pic of my shock/bump stop"
  2. Aug 10, 2011 at 8:01 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Timbrens ?
  3. Aug 10, 2011 at 8:19 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    They compress down to the same size as stocks though right?
  4. Aug 10, 2011 at 8:32 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    How long are your U bolts? You could always put a few sticks of 1/4" plate between your bumps and the leaf packs assuming your U bolts are long enough.
  5. Aug 10, 2011 at 8:37 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    They compress (not sure how far) but are intended to help carry a load so if they did manage to bottom out, it'd be a soft bottoming out, not a hard one. Timbrens are taller than stock bumps so you said the longer ones were barely too long, these might work for you.
    Or do what JLee said and give yourself a little extra lift.
  6. Aug 10, 2011 at 8:38 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    it wont give you extra lift, he means put it under the bump stop not the axle:)
  7. Aug 10, 2011 at 8:44 AM
    Pugga
    Massachusetts
    Ooh... I misunderstood what he was telling him to do :eek: That's a much better idea. The old brain isn't working well today...
  8. Aug 10, 2011 at 8:58 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I do have the longer Ubolts, so this could work.
  9. Aug 10, 2011 at 10:08 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Weld a piece to the frame side where the bump stop hits, so that it makes contact sooner.
  10. Feb 20, 2012 at 2:35 AM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 5 speed
    New Taco: 96 DLX Extended Cab 4x4 2.7, 5 speed, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    I am in the same situation. Have not fully ordered my kit yet, but plan on running a 2'' aal non tsb in the rear with the extended bilsteins. DSM advised me to extend my bump stops, but I am having trouble figuring out an easy way to do that.
    One Idea I had, is to take a 1''block and put it on top of the leaf springs but underneath the bump stop. Toytec sells this one with extended U bolts. Could this work? would it extend it too much?
    http://www.toyteclifts.com/index.ph...tegory_id=116&option=com_virtuemart&Itemid=72
  11. Feb 20, 2012 at 6:52 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    ^^This^^
    Pickup a block spacer and put it on the top of the leaf pack to raise the bump stop. That way it will have a pin to keep it from moving.
