Bump stop spacer?
Discussion in 'Long Travel Suspension' started by Drakivnsf, Mar 25, 2014.
  1. Mar 25, 2014 at 6:19 PM
    Drakivnsf
    Drakivnsf [OP] Dance Party Guru
    Socal
    '12 White Tacoma DCLB 4x4
    TRD Supercharger, URD CAI, BRP pre-axle catback, Anytime Rearview Camera mod, Power Sliding rear window, Glassworks Unlimited Front Fenders, ScS Stealth 6 wheels, Nitto Terra Grapplers 285/70/17, 3" All-Pro Std Leafs, 2.0 Fox adj. res. shocks, 2.5 Fox res. Coilovers, All-Pro +2" LT kit, Timbren Bumpstops front and rear, All-Pro U-Bolt flip kit, Pelfreybilt Hybrid front bumper, RCI IFS Skid, RCI Sliders, more to come.....
    Here is a link to the thread of my issue if anyone can help me figure this out.
    http://www.tacomaworld.com/forum/suspension/321830-crazy-bottom-out.html
    My question is do I need a spacer for my bump stop? Anyone else run a setup similar to mine? And the next question is will raising it by preloading the spring more and leveling the driver side to get rid of the taco lean maybe aleviate my issue? it only did it on the driver side, and nothing hit on the passenger side.
  2. Mar 29, 2014 at 9:28 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    I would clearance the fender before limiting the bump travel.
    Cut off the tabs, grind it smooth, take a rubber mallet and pound it out as much as you can. The tire will do the rest.
  3. Apr 7, 2014 at 7:18 PM
    Drakivnsf
    Socal
    ok thanks I was planning on doing that anyways. I think I am just going to get a set of superbumps to swap out to and then sell these timbrens.
