bump stops?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lotsoftoys, Mar 30, 2013.
  1. Mar 30, 2013 at 8:10 PM
    lotsoftoys
    lotsoftoys [OP] pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Does anyone make taller/softer bump stops for factory lcas? I know wheelers makes some nice ones for second gens.... wonder if those would work?
  2. Mar 31, 2013 at 12:32 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hmmm..I thought there were some for 1st gens..
    Why do you need them??
  3. Mar 31, 2013 at 12:34 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I thought daystar make some for 1gens
  4. Mar 31, 2013 at 8:18 AM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    check my build monte... and yeah i cant find any????
  5. Mar 31, 2013 at 12:01 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    What do you expect to gain from that ?
    Limit up travel ? for why ? (<-- edit for fubar)
    why would you want to limit the front suspension's travel...
    when it is already lacking in that :confused: :notsure:
    I'd lose those Top Load spacers instead.
    Those are a poor choice for pre-loading the suspension
    and fubar the upper/lower control arm geometry.
  6. Mar 31, 2013 at 3:49 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    limit down travel? what r u smokin over there chief? lol.... bumps limit up travel so my tires don't try to eat my fenders....
    and my top plate spacers dont preload the suspension at all, they are ON TOP of the shock mount, so all they do is give me extra lift.
    and my alignment/geometry is perfect:D
  7. Mar 31, 2013 at 4:42 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    The factory bump stops are actually different sizes between the front and rear. One is larger than the other, so there's no cookie cutter bump stop you'll be able to use out of the box.
    The threads on the bump bolts are actually considerably long, and there is room to stuff a spacer in between. We actually have to extend the bump stops using spacers with LT kits.
    That said...in the aftermarket world:
    http://www.polyperformance.com/shop/Daystar-EVS-Foam-1-3-8-X-2-1-2-Diameter-Bump-Stop-p-25912.html
    These are slightly larger than factory...but the are flexier than factory as well.
    Also the thread pitch is different (SAE vs metric) so you'll have to run a tap through your existing threads and a dab of Locktite. At a minimum you'll have to add a washer to one of them so the bump at the same time.
    Now all that said...I think you just need a bigger hammer and actually cut your fenders some. It's a complete waste to limit uptravel like that when you just need to do a little trimming.
  8. Mar 31, 2013 at 6:41 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    appreciate the info^ its hard to explain, but its not an issue of trimming. they tuck just fine, but if rollin through some whoops and turned slightly my whole top of the tire is gonna take out the liner.... i was about a 1/4 inch from the liner.... but ok spacers is a good idea, ill come up with something. hard to explain, these tires tuck wayyyyy up there
  9. Mar 31, 2013 at 6:44 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I meant up travel :eek:
    not thinking too clear as of late.
    should stop before I make a bigger mess
    yeah top load spacer don't pre-load the coil spring
    ^ ~was thinking while typing, that coil spring pre-load would be better
    so I typed without reloading muh brain~
    But top spacers will change the suspension's geometry.
    Being on top of the coil effectively makes the CO longer then OEM.
    This can change the plane that both UCA/LCA share.
    Extended length CO's also share a longer length...
    but is not the same deal...
    droop length is extended... but overall compression remains oem.
    Not the same thing as a CO with a spacer stacked on top.
    doesn't mean you can't align it to specification
    yeah that ^
  10. Mar 31, 2013 at 6:47 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    its all good brotha, i figured u had to be reading it wrong... but what's ur point with the alignment staying while compressed? no suspension will stay the same as it cycles
  11. Mar 31, 2013 at 6:59 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You do realize you're talking to someone that put holes in his core support to get more uptravel. I think your definition of "wayyyyy up there" and mine might be a little different.
    Seriously, cut the liners. It's just plastic, and it's free, and you don't lose anything from it. Can't say the same about your current plan of extended bump stops.
  12. Mar 31, 2013 at 7:03 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    yeah but u have glass fenders id have to remove the fender liners completely. then that allows all the shit the tire throws to be thrown into the fender. ill figure it out. i would of liked to have some soft bumps like the wheelers for second gens
  13. Mar 31, 2013 at 7:04 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    for reference....
  14. Mar 31, 2013 at 7:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ummm...no. Shock positioning does not cause bump steer. The little 10mm top plate spacers are nothing. The upper and lower mounts are identical, as is the UCA and LCA mounts, as is the tie rod mounts and all the geometry. As you said, It just moves the coilover assembly down. Which in this case will cause the shock to bottom out sooner but can also allow it to droop out farther if the BJ allows. The additional droop can be of concern for bump steer, but with the little 10mm spacer, that's less than the extended travel coilovers. The upper/lower positioning with respect to the spindle is what dictates the plane of travel, not the shock.
    Read above.
  15. Mar 31, 2013 at 7:18 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I had fenderliners at one point too...they've since been removed. It's not as big a deal as you think.
    Seriously, let the tires bump the plastics. If they come off they come off, it's not going to hurt anything.
  16. Mar 31, 2013 at 7:20 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i understand they r just plastic man, but id rather not have rocks and snow get thrown into places it shouldn't be. I'm pretty sure the liner block my headlights, those r expensive! I'm keeping the liners.
  17. Mar 31, 2013 at 7:24 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I'm just trying to set your mind at ease about it.
    I go through the same sand, salt, snow, mud, grime and shit you do, and have been for years.
  18. Mar 31, 2013 at 7:25 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i hear ya... just to each his own i guess.
  19. Apr 1, 2013 at 3:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm also running no liners.
    And Jace the liners will just flex. They bend. I wouldn't limit your up travel just to save the inner liners. And if they do fall out.
    Do this
    Just go buy some thin like 1/16 or thinner sheet of abs or any plastic. Then make your own liner that only attaches to the inner part. Then it'll rest on the lip of the outer fender and if the tire hits. It'll just move up..then back down. Here is a reference.
    http://www.tacomaworld.com/forum/long-travel-suspension/230146-fiberglass-fender-mud-blocks.html
  20. Apr 1, 2013 at 5:15 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    heh...heh...heh... I didn't hear water on that one.
