Bump when down shifting 5 to 4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sonofliberty92, May 11, 2022.
  1. May 11, 2022 at 1:44 PM
    Sonofliberty92
    Sonofliberty92 [OP] T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Truck is relativiley new to me. 43k miles. I'm not sure if I'm going crazy or it's another characteristic of these 5 speed auto transmissions. But sometimes there will be a bump down shifting from 5 to 4 coming to a stop or turn or whatever. Is this the torque converter unlocking/gear downshift or an abnormality? It will normally be a smooth downshift or an engine break downshift going down hill but every so often I get a bump or a knocking feeling coming out of 5th around 35mph coming off the highway or slowing down from traveling.
  2. May 11, 2022 at 2:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine has done it. It doesn’t do it regularly. Maybe a few times a year?
    And just like you, it’s usually when coming to a stop from higher speed.
    And yes. Before someone suggested I check my fluid level, it is full.
    Typically if the fluid is low, it will jerk into gear all the time, or most of the time.
    BTW, mines done it since I’ve owned it. 13 years now.
  3. May 11, 2022 at 2:58 PM
    Sonofliberty92
    Mark
    Maryland 4 South
    Thanks for the reply. I just took the truck out and drove for about an hour and it didn't do it the entire time. I'm getting a friend of mine who works at Toyota parts to get me some ATF fluid cheap and I'm gonna do a drain and fill and check the fluid. It seems like if I've been driving the truck for a while I'll get smoother shifts all around. It hasn't been really cold or anything. Mid 50s and 60s. Idk perhaps I'm a hypochondriac. I'll notice something and keep focusing on it. Just want my truck to last as long as my dad's previous Toyota trucks. 400k miles and he's never changed the damn tranny fluid.
    TnShooter[QUOTED] likes this.
  4. May 11, 2022 at 5:04 PM
    TnShooter
    Deogee
    STOCK
    I did a drain and fill at 100k.
    It wouldn’t be a bad idea to do it every 50k.
    Some guys drop the pan and change the filter, I didn’t and have not yet.
  5. May 11, 2022 at 5:06 PM
    Sonofliberty92
    Mark
    Maryland 4 South
    I did one about 5000 miles ago but this time around I'm gonna do it myself and check the fluid level. You never know what you get at a dealership
    Dm93 and TnShooter[QUOTED] like this.
  6. May 11, 2022 at 6:19 PM
    Glazed_Ham
    Glazed_Ham Member
    2013 tacoma off road
    Funny mine just started doing that but from 4th to 5th.
    Sonofliberty92[OP] likes this.
  7. May 11, 2022 at 7:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the 4 to 5 and 5 to 4 shift under just the right circumstances can be uh... odd. Just a characteristic of the stock tuning of the truck.
    New to you truck, I dont care how many miles it does or doesnt have, or what maintenance records show. But change all the fluids properly (theres a special procedure for the trans fluid fill level). Front diff, tcase, trans, rear diff, engine oil, brake fluid, radiator fluid etc.
    Sonofliberty92[OP] and TnShooter like this.
  8. May 12, 2022 at 4:08 AM
    Sonofliberty92
    Mark
    Maryland 4 South
    Yea I'm aware of the procedure with the ATF fluid. Everything else was done the first 2 months I had it. Coolant flush, PS fluid, diffs and transfer case, plugs, oil twice now, greased the drive shaft u joints, trans drain and fill, now I'm about to do the drain and fill again.
    nd4spdbh[QUOTED] likes this.
  9. May 12, 2022 at 4:10 AM
    Sonofliberty92
    Mark
    Maryland 4 South
    Mine was doing it up shifting at first now it does it down shifting under the right circumstances. My wife thinks I'm crazy. She's probably right.
  10. May 12, 2022 at 7:05 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I noticed my truck doing it when the u-joints/carrier bearing were going bad. Now that I’ve changed all that out, I have to pay attention to notice it.
