Bumper Height
Discussion in 'Northern California' started by TheKid, May 7, 2012.
  1. May 7, 2012 at 6:32 PM
    TheKid
    TheKid [OP] Well-Known Member
    Bay Area, Ca
    2011 Tacoma
    Hey guys, I put a Leveling kit on my truck, and I'm pretty sure I'm going to lift it higher because I think it will be cheaper that buying small tires. But I want to get a Tube Bumper. Is there any laws in California about bumper height or anything I should know about before I buy one? I live in Contra Costa County if that makes a difference.
    Thanks for the help.
  2. May 22, 2012 at 4:55 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    nope there shouldnt be any particular laws for tube bumpers in CA.
    Im in Concord/Clayton btw.
    so is Shemicals, Acdronin, babytrucks, and t4r4life.
  3. May 22, 2012 at 5:49 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    You'd have to check CA vehicle codes. I know in Washington State the bumper laws are pretty strict.
    (a) Be at least four and one-half inches in vertical height.
    (b) Be centered on the vehicle's centerline.
    (c) Extend no less than the width of the respective wheel track distances.
    (d) Be attached to the vehicle in a manner equivalent to the original manufacturer's installation.
    (e) Be horizontal load bearing and attach to the vehicle frame to effectively transfer energy when impacted.
    (f) Be mounted at a maximum height based on the original gross vehicle weight rating (GVWR) of the vehicle, measured from a level surface to the highest point on the bottom of the bumper. For vehicles exempted from the bumper requirement for the reasons stated above, a maximum frame elevation measurement must be made to the bottom of the frame rail. Maximum heights are as follows:
    Front Back
    Passenger Vehicles: Front: 22 Inches Rear:22 Inches
    4,500 lbs. and under GVWR: Front: 24 Inches Rear: 26 Inches
    4,501 lbs. to 7,500 lbs. GVWR: Front: 27 Inches Rear: 29 Inches
    7,501 lbs. and over GVWR: Front: 28 Inches Rear: 30 Inches
  4. May 22, 2012 at 11:18 PM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    non of this matters, cop will pull you over if they feel like it and give you shit. if you get pulled over by a cop and get a ticket, tell him to go eat a bag of dicks, put back the stock bumper, get it signed and put the tube bumper back on.
  5. May 23, 2012 at 9:33 AM
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    I only know about the minimum height, 12 inches but since youre not lowering it then dont worry about it.
    Still, little bit of info for you.
  6. May 23, 2012 at 8:09 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    CVC 28070 and 28071
    In a nutshell...it means there's no such thing as a "legal" aftermarket bumper in CA. Bumper height is not an issue, but the minute you pull off the original manufacture equipped bumper, the great LEOs of California can give you a fix it ticket. :rolleyes:
  7. May 23, 2012 at 8:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And the next time he sees you, he'll flag the ticket as "non-correctable" and you'll have a large fine on top of the sign-off and $30.
    I've talked to a LOT of cops who are automatically going "non-correctable" for tint, HIDs/tinted headlights, etc...
    Their attitude is that the "fixit" is for something that's broken and the owner just needs a "kick in the ass" to get it fixed, but they aren't going to cut that break for the owner that intentionally does something illegal.
  8. May 23, 2012 at 8:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    What's the CVC? I don't remember ever seeing a minimum or maximum bumper requirement.
    Height requirements I know of are:
    Headlight height is between 22" and 54" in height.
    Exhaust height if exiting to the side must be 24" or less.
    Frame height up to 4,500 pounds GVWR is 27 inches, 4,501 to 7,500 pounds GVWR is 30 inches, 7,501 to 10,000 pounds GVWR is 31 inches.
  9. May 23, 2012 at 8:21 PM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
    or if the owner/driver has a "mouth" problem.
  10. May 23, 2012 at 8:23 PM
    Teniente
    If I remember correctly, the bottom of rear license plate must be at least 12" above the roadway.......
  11. May 23, 2012 at 8:27 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    True... "Eat a bag of dicks" never ends well for the guy that doesn't have the badge.
  12. May 23, 2012 at 8:30 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You are correct there. Rear plate is 12"-60",but there's no miniumum on front plate (max is still 60" though). Still, I don't think there's a requirement that the license plate be attached to a bumper.
    CVC 5201
    EDIT: Just noticed you're from Carson City. I'll be moving to Zephyr Cove next week. Let's hit some trails!
  13. May 23, 2012 at 9:46 PM
    TheKid
    Bay Area, Ca
    2011 Tacoma
    Thanks for the help guys
    I'll keep a eye out around Concord for your trucks
  14. May 24, 2012 at 7:23 AM
    DangerTaco
    Max
    '03 Tacoma TRD
    thinkin about it now i think the minimum height for the headlights is 12 inches, my bad.
    Its mainly for the ricer boys and their lowered cars, etc.
