Bumper install help
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoSauce04, Jul 10, 2017.
  1. Jul 10, 2017 at 5:40 PM
    TacoSauce04
    TacoSauce04 [OP] Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    I bought this addicted offroad bumper off a 4runner. It was pretty rusty and had some nasty black house paint that had mostly peeled off. After alot of elbow grease i restored it back to life. Now im ready to install it and im not sure how to begin. I removed the oem bumpe, front skid plate and curved cross member already. Im not sure what else to remove or cut of the front of the truck to begin fabbing up the new cross member. I bought a 2x3-48"steel tube to begin designing a new cross member but im not sure if a C channel would work better. I do have access to a cutting wheel and can prob find a shop to help with the welding. If anyone is in the houston area id gladly pay for some tacoma enthusiast welding help. Any advise would be great.
    BassAckwards likes this.
  2. Jul 10, 2017 at 5:46 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Check out @cynicalrider build. Pretty sure I remember reading where he fabbed a cross member for that bumper.
  3. Jul 10, 2017 at 5:47 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Honestly that looks like its bolt on to me..
  4. Jul 10, 2017 at 5:47 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    First off. Those two protruding frame cans need to be unbolted.
    Ritchie likes this.
  5. Jul 10, 2017 at 5:48 PM
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Do the four bolts not match the holes? I'd say if not why don't you cut off the studs and start building off there, now Just weld it to where the curved bar was and build off there
  6. Jul 10, 2017 at 6:39 PM
    TacoSauce04
    David
    ARE Shell
    @3rYODA, I tried to direct bolt on to the two protruding frame cans but they are different dimensions. The bumpers bolt holes are narrower than the frame can bolts.
    Why do the cans need to be removed @License2Ill? If i remove them, what and how will i attach the crossmember?
    Thanks for the quick response, im trying to finish this one of many projects before a trip to Colorado next month.
    Thank again.
  7. Jul 10, 2017 at 7:02 PM
    toyota700
    toyota700 Well-Known Member
    Dan
    cos, co
    01 3RZ Reg
    You could contact Scotty and just buy the crossmember from him. Might make things a whole lot simpler. :notsure:
  8. Jul 10, 2017 at 8:36 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I had to take those frame cans off when I installed my trailgear bumper because it comes with this mounting crossmember type thing like this. Then you bolt the trailgear bumper onto that and you're done. These are Google images too. Just to explain. Not my truck. But this is what had to be done. GL!
  9. Jul 11, 2017 at 2:31 PM
    License2Ill
    Ian
    You don't want the leverage of the weight of the bumper on those things if you want the bumper to stay attached to your vehicle. But it looks like you need the cross member that originally came with that bumper anyhow...
  10. Jul 11, 2017 at 2:47 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    from the looks of it, the trailgear mountain plate might work. You can buy just the mountain plate alone. http://www.trail-gear.com/product/4716/rock-defense-tacoma-front-bumper-mounting-plate
    Fuergrissa likes this.
  11. Jul 12, 2017 at 2:48 PM
    TacoSauce04
    David
    ARE Shell
    Thanks guys, ive since removed the cans. After some measuring I think I am ready to start cutting and drilling the 2x3. The cross member will bolt up the the two bolt holes that were holding the cans. The two cans had a thinner cross member bridging across the cans that the skid plated bolted to. I guess I have to add some plate tabs for those bolts under the new cross member. I'm also going to bolt a plate tab to where the front skid plate bolted up to.confusing I know. I take some pics as I go. Thanks again
  12. Jul 12, 2017 at 6:03 PM
    TacoSauce04
    David
    ARE Shell
    Ok so i mounted the cross member. Now i have to transfer bumber bolt holes to the crossmember and drill them out. The real challenge will be getting the nut on the inside of the tube to line up with the bolt through the bumper and crossmember. I thought about doing the same thing i did on the front and bore out a bigger hole but that process took forever for 2 bolts. The bumper has 6 total. I could just cut out some rectangular pieces out the back. That would give me enough room to tack weld the nuts on the inside of the tube also.
  13. Jul 13, 2017 at 9:30 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Have you placed the bumper on to the cross member to see how far out the bumper sticks?
    frenchee likes this.
  14. Jul 13, 2017 at 10:20 AM
    TacoSauce04
    David
    ARE Shell
    Yes. I also put it up to the frame bolt holes to see if a C-channel would work better but the center tube arch his the truck body and would make fitting a winch impossible, I think. I want to install winch in the future but I'm not sure what type to go with. I won't be using it alot so I was thinking of buying one from harbor freight. What are yalls thoughts? How much weight rated winch should I buy?
  15. Jul 13, 2017 at 10:25 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    that bumper looks modified to me. i mean look at those welds for the mount
  16. Jul 13, 2017 at 10:40 AM
    TacoSauce04
    David
    ARE Shell
  17. Jul 13, 2017 at 11:02 AM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    ^this will work, the bumper mount comes, with hardware needed for everything if you buy the mount you'll be set. The three holes will on you bumper will line up with the holes on the mount.
    @TacoSauce04
    Since your making your own mount I'd make sure it's secured properly, the two bolts you currently have with the crossmember might hold your bumper up but it won't be safe, the bolts are in direct shear, utilize the threads in the circle with arrows going to it. Unbolt the hoop and use those as mounting points as well.
    Good luck!
    chowwwww[QUOTED] likes this.
  18. Jul 13, 2017 at 5:32 PM
    TacoSauce04
    David
    ARE Shell
    Thanks for the advise. I plan on welding the flat bar that is supporting the crossmember to the frame and to the crossmember. The flat bar is currently bolted behind that loop to the underside of the frame.
    I wasnt planning on using those two side bolt holes but i see what your saying. Ill do some sketches to see if i can bolt in those 2 holes.
  19. Jul 14, 2017 at 1:27 PM
    TacoSauce04
    David
    ARE Shell
    I bolted up the bumper. Im going to reinforce it with some more flat bar and welding. It should be roadworthy soon. Im also gonna spray the background paint and crossmember with POR black paint.
    nw_chris and Fuergrissa like this.
  20. Jul 14, 2017 at 3:21 PM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    I guessing you already took care of the turn signal mod, you guna relocate the windsheild wiperfluid?
