Bumper Instructions
Discussion in 'All-Pro Off Road' started by Masada, Oct 12, 2009.
  1. Oct 12, 2009 at 6:17 PM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Hi All Pro,
    I am looking at buying your front bumper for my 05 Tacoma and was wondering if I could get a PDF copy of the install instructions. I would just like to see what all is required. My truck was recently in a small accident that took off the front bumper cover and destroyed the aluminum bumper so I want to make sure I have all the necessary parts.
    Thanks for your time.
    Oh and if you have any hints or tips to pass along that would make the install easier I would appreciate it.
  2. Oct 13, 2009 at 3:31 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    pretty much the plastic bumper cover, aluminum support behind it, and thats about it thats taken off. the 3 bolts on each side that the aluminum bar was mounted is where u mount the AP one. *TIP* if u have to so this urself or w/ limited help, install it in pieces to the truck then have someone hold the wings long enough for you to bolt them and u should be good. oh...and if u get the light bar, dont be surprised if all 4 holes dont line up
  3. Oct 13, 2009 at 9:22 AM
    Masada
    Taylor
    Laveen, AZ
    No, i'm not getting the light bar so I won't have to worry about that.
    Is this thing like UBER heavy? How much would you say it ways? 50lbs, 100lbs, 150lbs?
    I didn't think you could put it on in pieces, that will help thanks...
  4. Oct 14, 2009 at 3:51 PM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Weighs just under 100 lbs. PM me your email address and I'll get you a copy of the instructions.
