Bumper light socket
Discussion in '1st Gen. Tacomas' started by mnger9, Apr 30, 2013.
  1. mnger9
    mnger9 [OP] Member
    Jerry
    Ohio
    04 Prerunner double cab
    I'm a newbie on here, and a newbie to owning a Tacoma. I have an 04 Tacoma Prerunner. I had a problem with the bumper light fogging and I bought replacement lenses for it. It stayed good for a while, but started fogging again. Eventually burnt the bulb out, then it burnt the plug and socket assembly out. I found the female plug that is attached to the harness, but I cannot locate the bulb socket anywhere. I did find a couple places selling the lens with the socket, but my lenses are new and don't need another one. Not sure if this was originally a turn signal. When I bought it (used), it had 3157 bulbs installed, and I like the extra light they put off. Any help would be greatly appreciated! :confused:
  2. mnger9
    mnger9 [OP] Member
    Jerry
    Ohio
    The bulb socket with the male end is the part I am searching for
  3. mnger9
    mnger9 [OP] Member
    Jerry
    Ohio
    Was in a rush last night to post my questions on this forum as I had to work, however after having more time to research it, this originally was a turn signal, and had been converted to a clear running light of sorts. I was able to find the proper plug or socket assembly (toyota part #81515a), and my question now is: Is the 3157 bulb in this wiring configuration overloading the circuit?, or is my problem with the fried plug a fluke, and/or probably due to the moisture in the lens housing?.
  4. mnger9
    mnger9 [OP] Member
    Jerry
    Ohio
    Well, I received both male and female plugs in the mail. However, I did not realize the female harness end did not come prewired. Since my plug had burnt up, I needed the female connections inside the housing as well. Well after locating a Toyota manual online, dedicated solely for the repair of Toyota plug assemblies, I found what I was looking for. They actually make prefabricated pigtail assemblies with the proper wire termination as well as a preinstalled grommet to make the assembly water proof. I must say that I was impressed to find a 400-plus page manual dedicated to repairing plug connections, even though I found what I was looking for on page 360 or so. My problem lied with the socket leaking water inside the lens and it actually made it back to the plug connections where it shorted out. So I will wait for my terminations to come in the mail and get them soldered to the harness when they come in. Sorry this post is so long, but I really wanted to share with people on here the fact that Toyota created a repair manual just for plug assemblies. It came in quite handy, even though some areas were somewhat cryptic.
