Bumper Mount Deformation - Repair?
Discussion in 'Armor' started by Naveronski, Oct 28, 2018.
  1. Oct 28, 2018 at 4:27 PM
    Naveronski
    Naveronski [OP] Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Over the past weekend, my winch was used heavily to recover people and drag them up a hill. Unfortunately, that has done a number on my bumper mounts.
    Here is the driver's side. Notice the bend in the mounting plate, and the gap forming between it and the bumper.
    The passenger side is even worse.
    It has resulted in quite a gap where the bumper should meet the headlights.
    And because of the angle, it is rubbing the underside of my fenders.
    Worst of all, it's allowing the bumper to move. If I grab the front hoop, I can wiggle the bumper up and down... not exactly inspiring confidence. I need to get this fixed!
    I know @RelentlessFab @RelentlessFabrication makes a bracing plate for their bumpers to prevent this exact thing, but I'm not positive it will help, or that it would be compatible with my @Icon_Adrian remote reservoir mounts.
    How have y'all fixed this?
    Icon_Adrian and SuperBad like this.
  2. Oct 28, 2018 at 5:04 PM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    I honestly think that you need these to help support the pulling of the bumper...
    @RelentlessFab not to distract from the thread, but any way that I can order just those supports to help tie in and brace my not relentless front bumper?
    I already have this type of brace, but more would be better I think?
    Not My Picture, just got it from @greeneggsnspam
    Icon_Adrian and AR15xAR10 like this.
  3. Oct 28, 2018 at 5:10 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  4. Oct 28, 2018 at 5:17 PM
    ETXTacoma
    Steven
    Tyler, Texas
    lordetaco and tacoma16[QUOTED] like this.
  5. Oct 28, 2018 at 5:20 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    its on the list for me...
    Bocsy44 likes this.
  6. Oct 28, 2018 at 5:24 PM
    ETXTacoma
    Steven
    Tyler, Texas
    Would def be pretty nice! I have the reinforcements like the second picture I posted, but am going to add in the top style reinforcements as well.
  7. Oct 28, 2018 at 5:24 PM
    n0troublen0fuss
    n0troublen0fuss Well-Known Member
    Kevin
    Texas
    2013 DCSB 4x4 Base
  8. Oct 28, 2018 at 5:24 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You should also look into getting your bumper mounts welded back on. There are reinforced mount mods for that in TW.
    I believe it was from Relentless where I got my bumper braces. Its been 4 years so I don’t remember exactly.
  9. Oct 28, 2018 at 5:28 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I currently have the relentless style with a relentless bumper. The issue is the frame not the bumper.
  10. Oct 28, 2018 at 5:34 PM
    ETXTacoma
    Steven
    Tyler, Texas
    Yea, that metal is just way to thin for the bumper supports and needing to tie it into the frame more is needed.
    tacoma16[QUOTED] likes this.
  11. Oct 28, 2018 at 5:54 PM
    Naveronski
    Fort Worth
    Thanks. I've found a set of the Relentless braces locally, so that will be part of my solution. I'll have to modify my Icon RR supports to fit.
    There's also these: http://sosoffroadconcepts.com/weld-on-frame-brace/
    I may need something similar to that, as well.
    ETXTacoma likes this.
  12. Oct 28, 2018 at 5:55 PM
    Naveronski
    Fort Worth
  13. Oct 28, 2018 at 6:32 PM
    ETXTacoma
    Steven
    Tyler, Texas
    Just ordered a set of frame braces from @At The Helm, and per him "Includes frame tie-in brackets and grade 8 bolts. If running remote reservoir shocks, modification of shock brackets may be necessary."
    I have not had this issue, but when I get a winch or need more pulling like Saturday, this will help support the bumper even more now.
    Biscuits and At The Helm like this.
  14. Oct 29, 2018 at 7:25 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    We need to talk to Alex about this, he's got the fancy plasma cutter now
  15. Oct 29, 2018 at 10:01 AM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    I have seen some bumper plates that come in the path of the Icon Reservoir Bracket and the fix/modification is pretty easy. Some bumper plates will simply sandwich the reservoir bracket and some will require drilling a hole in the reservoir bracket in order to incorporate it.
    ETXTacoma and n0troublen0fuss like this.
  16. Oct 29, 2018 at 10:20 AM
    Naveronski
    Fort Worth
    Good; neither of those sound like a real problem.
  17. Nov 1, 2018 at 6:27 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Reservoir mount is thin. I just drilled through it.
  18. Nov 1, 2018 at 6:35 PM
    Naveronski
    Fort Worth
    Good to know! That’s my plan, too.
    Thank you for posting the photo.
    Icon_Adrian and n0troublen0fuss like this.
  19. Jan 24, 2024 at 12:20 AM
    TacoTuesday1
    FL
    researching to try and figure out
    want to ask
    is this necessary? Does it fit?
    so, the video says:
    -the stock bumper mounts are weak. Replace it with theirs that are stronger. But it requires welding.
    It claims theirs are beefier, potentially including studs. Which brings the question, does that mean their studs are too big to fit a steel bumper designed to bolt onto a stock truck
    1. why is a side brace not enough
    2. does anyone know how this pertains to ARB bumpers
    ARB being reputable, I would hope it's not a concern.
    If I recall, mounting my ARB front it came with additional parts to secure it. It was not simply "couple nuts onto the front studs"
    https://images.carid.com/arb/off-road-bumpers/pdf/arb3423030-installation-instructions.pdf
    it comes with triangular side brackets for example
    Not sure if beefier other company side braces would fit instead, or be necessary in place of what the ARB comes with if they do fit.
  20. Jan 25, 2024 at 6:51 AM
    Naveronski
    Fort Worth
    Complicated answer - "it depends"
    It depends on how you intend to use your truck. I use my winch a lot, and as you can see in the older posts, I needed to flatten my frame horns and weld in a reinforcement plate. I like the design in the video better, especially with the cross tube, but it hasn't been necessary yet for me. I did add a side brace and I immediately noticed a big improvement.
    I am still using the Toyota studs. I don't think they've cracked... but honestly I should check them specifically.
