Bumper parking lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by IndianaSteve, Mar 27, 2017.
  1. Mar 27, 2017 at 2:07 PM
    IndianaSteve
    IndianaSteve [OP] Member
    '04 Tacoma SR5 TRD
    Have a 2004 Tacoma, new to me. All of my lights work EXCEPT the front bumper parking lights. I checked the bulbs and they are dual filament, Haynes schematic says they are supposed to be dual filament BUT the factory socket is only 2 wire not 3. There is no grounding on the light assembly so the socket is not made for a turn signal/parking light bulb. Has anyone seen this? Or am I being stupid and missing something?
  2. Mar 27, 2017 at 2:41 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    The lights on the bumper are turn signals. Your parking lights are next to the headlights (Unless you did the blinker relocation mod)
  3. Mar 27, 2017 at 2:42 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    From the factory the lower bumper lights are set up to be turn signals only, despite the dual filaments. The parking lights are the small corner lights next to the headlights.
    You can easily make them parking lights as well by running a wire from the corner light down to the third connector receptacle. That way they turn on with the corner lights, and still blink brighter for turn signals. I'm sure there's a write-up somewhere, but I can't find it at the moment. Did it years ago with zero issues.
    Dalandser likes this.
  4. Mar 27, 2017 at 2:53 PM
    IndianaSteve
    '04 Tacoma SR5 TRD
    That's very interesting, think I will connect to the corner lights.
  5. Mar 27, 2017 at 3:51 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Check these out
    https://www.tacomaworld.com/threads...-thread-compiled-list-of-helpful-links.95271/
  6. Mar 28, 2017 at 5:41 AM
    michaelsdaddy02
    michaelsdaddy02 Well-Known Member
    New Jersey
    04 Double Cab 4x4 3.8 SR5
    I plan I pulling my out. And changing to a Feneix dual color hide a way leds. Amber and clear. Then Ill have turn signals, driving lights, and warning for snow removal.
  7. Mar 28, 2017 at 6:27 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I added another wire to the socket to get both lights working, then had switchbacks.
    However, keep in mind the 3157 bulbs that are in it are standard and will blow the fuse if you don't buy CK style 3157. the socket uses the ground on the same side (CK) as opposed to grounds on both sides (normal).
  8. Apr 5, 2017 at 2:43 PM
    POBOX144CHINO
    POBOX144CHINO Member
    ANDRADE
    2004 Tacoma TRD
  9. Apr 5, 2017 at 2:45 PM
    POBOX144CHINO
    ANDRADE
    2004 Tacoma TRD
  10. Apr 5, 2017 at 9:05 PM
    tn_popo
    tn_popo OINK
    Billy
    East Tennessee
    '18 Tacoma DCSB TRD Sport V6 Inferno
  11. Apr 5, 2017 at 10:31 PM
    POBOX144CHINO
    ANDRADE
    2004 Tacoma TRD
    No, write up. But I'm willing to help you out. As mentioned on the video. Mtucker is the reason I took on this project :bowdown:. His write up is on the below link . I basically followed his write up but used V-Leds V-tritons! The new v-tritons are much brighter and have a much smaller round blub, by filing down the housing socket slots on the corners the bulbs fit great. I also have my rear brakes and turn signal with v-tritons, but also had to chisel out the openings to make the bulb fit. I also deviated from mtucker write up a bit by wiring the Tritons direct, I removed the original toyota sockets and used the tritons harness direct. I also do not have any led resistors, I installed a LED blub electronic flasher. Makes a much cleaner job. Funny, V-leds emailed me saying this project could not be done.:brianr: I should post thier email asking me to send blubs back! The site allows you to buy the blubs for 2004 tacoma, but without chiseling out the socket housing they will not fit. You first must understand mtucker write up and than I can help you out further. https://www.tacomaworld.com/threads...g-lights-with-switchback-leds-a-how-to.85986/
