Bumper tow question!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09toyotacoma, Apr 3, 2011.
  1. Apr 3, 2011 at 7:01 PM
    09toyotacoma
    09toyotacoma [OP] Active Member
    NY
    09 4cyl 5spd 4x4 access cab
    I have 2009 access cab 4x4 and i need to tow a light about 700lbs tomorrow. I know that i should be using a hitch reciever but i cant have one on by tomorrow. I have all the wires ready but my question is is the bumper height of a 4x4 going to be a problem with a shorter utility trailer going to be a problem? Will the trailer tilt back to much and rub anywhere? i havent had a chance to try. Any feed back would be appreciated
  2. Apr 3, 2011 at 8:29 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    you would have to hook it up to the truck and see where it sits.
    are you planning on getting a hitch?
    u-haul can usually put one on preatty quick
