bumpers for 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95 taco, Oct 29, 2012.
  1. Feb 1, 2017 at 2:41 PM
    #121
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    With a front bumper and rear bumper, suspension change is a must?
  2. Feb 1, 2017 at 2:58 PM
    #122
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah, especially with that mileage on the original. I've only installed a suspension lift on a second gen, didn't really need it, customer just wanted to be taller. That being said, from what I've gather here, it sounds like for your needs; front springs - OME 880, front shocks - OME nitro chargers or Billies 5100 set at bottom or next step up, rear set up, not too positive. Maybe just add a leaf to existing, or new stock height leaf pack and then matching to the front OME or Billies rear shocks. Minimal lift but refreshing the suspension. Minimal lift so you don't get into that world of vibes and funky angles that need correcting, etc.
    PROseur[QUOTED] likes this.
  3. Feb 1, 2017 at 3:05 PM
    #123
    PROseur
    Pussy
    Thank you. As usual you ROCK harder than Dave Navarro!
    cruiserguy[QUOTED] likes this.
  4. Feb 1, 2017 at 3:36 PM
    #124
    cruiserguy
    Elijah
    SEKS
    Hold up now. We gotta get confirmation from the suspension gurus here. I'm not positive on it.
  5. Feb 1, 2017 at 3:54 PM
    #125
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yes you'll want coils that can hold the weight. The stock coils are 500lb progressive rate. Yours are so worn the top 3 coils are probably touching. They aren't 500lb anymore.
    You'll need something to hold the weight if you plan on that plate bumper.
  6. Feb 1, 2017 at 4:30 PM
    #126
    PROseur
    Pussy
    I will see if I can get some pics of the suspension tomorrow
  7. Feb 2, 2017 at 11:04 AM
    #127
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Only the TRD suspensions came with progressive coils. I doubt his are progressives. Still worn out tho.
    cruiserguy likes this.
  8. Feb 2, 2017 at 11:32 AM
    #128
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine where progressive on Igor. Not a TRD.
    Grant 4runner wasn't. Put those coils on my Moms taco rides way better.
  9. Feb 10, 2017 at 7:45 PM
    #129
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Subbbb. Love the thread. Good job guys.
