burn a quart of oil
Discussion in '4 Cylinder' started by timb, May 11, 2011.
  1. May 11, 2011 at 5:58 AM
    timb
    timb [OP] New Member
    I notice my 2.4 burns about a quart of oil every oil change about 3-4 thousand miles its a quart low. Have 180k miles,,,is this normal for this miles or should I do something like oil additive...........whats the cause? there is no oil leaks either
  2. May 11, 2011 at 6:34 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Perfectly normal for 180k mile engine.
    Hell the 2.4L in my wife's Camry burns a quart between oil changes and that motor has 92k on it...
  3. May 11, 2011 at 6:35 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    All engines should burn some oil between changes. Does it smoke on startup? If so, it either has an internal leak, or the oil control rings are wearing out. External leaks are easier to find, but not as easy to fix.
    More than a quart per 3000 miles is excessive. You are right on the tipping point. Make sure you eliminate external leaks before calling it a smoker!
    Additives are a band-aid and will either thicken the oil(BAD) or cause the seals to swell, which will only help leaky engines. Claims of sealing the cylinder walls and fixing the rings? Snake oil.
  4. May 11, 2011 at 7:12 AM
    05RedTaco
    Tony
    Scottsdale
    I wouldn't worry about 1quart between 3-4k miles. At 180k miles you run it till it dies or you rebuilt it completely, oil consumption is most likely caused by worn piston rings, which again on an engine with 180k is not surprising or unusual.
    The ghetto redneck way is to pour in some conventional 20w50...LOL
  5. May 11, 2011 at 11:34 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    20w50:) Works, but drops mpg, more startup wear, harder cold starts.
  6. May 19, 2011 at 3:11 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    My Dad's 2006 Highlander has a 2.7L engine like my truck has and neither one burns oil between changes, that we can tell... I suppose it might burn 1-2 ounces but it's never enough to notice on the stick, the level always appears the same after a change and before doing the next one.
    Couldn't agree more, definitely would fail a smog check burning that much.
