burn out vibration??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saltwater taco, Jan 21, 2010.
  1. Jan 21, 2010 at 3:41 PM
    saltwater taco
    saltwater taco [OP] Well-Known Member
    Brandon
    Telluride, CO
    2001 3.4 5spd 4x4 TRD
    softopper, sleeping platform
    i have an 06 prerunner sr5 and everytime i try to spin the tires it feels like my truck is falling apart. Is this traction control, vsc, lsd, or what? and how do i turn it off? ive read the mod about turning trac, abs, and vsc off but i cant locate a blue wire with a yellow stripe :(
  2. Jan 21, 2010 at 3:58 PM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    Why are you burning out the tires??
    But, it may be the traction control (my 09 has TRAC and beeps and shudders when a tire spins in snow). I've never had a reason to spin my tires on pavement so I couldn't say for that.
  3. Jan 21, 2010 at 4:09 PM
    Rhino8541
    Rhino8541 I like ze best!
    AZ
    2017 QS DCSB OR
    Age 19
    Gender: Dude
  4. Jan 21, 2010 at 4:11 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Burn!!!
  5. Jan 21, 2010 at 4:11 PM
    saltwater taco
    Brandon
    Telluride, CO
    ^^^ Exactly :) Though I only burnout in the dirt or when the road is wet.
  6. Jan 21, 2010 at 4:15 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    It is a factory "feature" to help increase fuel economy, tire life, and driver IQ by suggesting that this might be a bad idea.
    Just Razzing. Your problem is probably axle wrap caused by the rear axle rotating under load when the wheels have too much traction to spin easily. Besides the jumpy feeling this also rotates the pinion until the u-joints are out of tolerances and they get angry too. Lift blocks in the rear end increase the leverage and therefore make axle wrap worse as does Traction Control and LSDs/lockers. If you have traction control you can try turning it off by holding down the button on the dash. If this is the problem you can install a ladder/traction bar that helps by prevent the rear axle to rotate.
    http://www.4x4wire.com/jeep/tech/susp/axlewrap/
  7. Jan 21, 2010 at 4:18 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
  8. Jan 21, 2010 at 4:32 PM
    saltwater taco
    Brandon
    Telluride, CO
    Ok. I kind of understand.
  9. Jan 21, 2010 at 4:37 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
  10. Jan 21, 2010 at 4:48 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    You don't have traction, if you have a sport then u have LSD if it's an offroad then u have a locker if it's non trd then u have open rear differential
  11. Jan 21, 2010 at 4:59 PM
    saltwater taco
    Brandon
    Telluride, CO
    Its non trd. If its an open differential shouldn't there only be 1 tire mark in the dirt? Or is the traction control or whatever switching the power back and forth between tires?
  12. Jan 21, 2010 at 5:29 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    open diff means one tire spinning. the only tacos that have traction control are the 09s and up
  13. Jan 21, 2010 at 5:41 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    its called wheel hop or axle wrap is another common name for it. if your truck is doing this beware. you can/will break the ring and pinion gears in the rear end. ask me how i know....
  14. Jan 21, 2010 at 5:58 PM
    saltwater taco
    Brandon
    Telluride, CO
    So if I want to do burn outs, I have to add a ladder/traction bar? That's gay.
  15. Jan 21, 2010 at 8:17 PM
    4low2go
    Coatesville, PA
    10 RC 4x4 5sp MGM
  16. Jan 21, 2010 at 8:31 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Why would the thread get locked... it's perfectly legal and ok to do a burnout on private property, the drags, ect.
    Anyway, you'll eat tires, it's hard on the drive train, yatta yatta... I do it all the time and it's fine. I don't do brake stand sthough (hold the brake and gas). If you're just punching it hard on acceleration, she'll be fine. If you're holding hte break, there's a lot of tension building up in the drivetrain. The two piece drive shaft, the loose suspension, ect... it's not really designed for such abuse.
  17. Jan 21, 2010 at 8:42 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2 ive done both, and these trucks have enough power just to burn with out breaks, or at least mine does:D
  18. Jan 22, 2010 at 1:28 PM
    saltwater taco
    Brandon
    Telluride, CO
    All I do is floor it and not on dry pavement. I don't hold the brake or rev up and pop the clutch, but I usually feel some wheel hop or axle wrap. I guess i should just be less aggressive with my burnouts.:pout:
  19. Jan 22, 2010 at 1:58 PM
    saltwater taco
    Brandon
    Telluride, CO
    haha! I just do it for fun
  20. Jan 22, 2010 at 2:00 PM
    saltwater taco
    Brandon
    Telluride, CO
    That took me a minute to catch the burning rubbers part. Ahhh good stuff!
