Burn smell after using 4WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Juicifer, Feb 21, 2010.
  1. Feb 21, 2010 at 4:17 PM
    Juicifer
    Juicifer [OP] Member
    I just drove 50 miles in snowy weather with 4WD engaged, and when I parked and got out it smelled like something was burning. I've had previous truck smell a little bit after driving in 4wd but not this bad. Is this normal, and what causes it? I didn't see any smoke or leaks.
  2. Feb 21, 2010 at 4:22 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I personally don't think I've noticed a burning smell with my truck ever.
    Just curious, were those 50 miles of roads snow covered?
  3. Feb 21, 2010 at 4:30 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    your truck a manual? is it brand new?
  4. Feb 21, 2010 at 4:34 PM
    Juicifer
    '09 TRD Automatic, 10k. I probably have several hundred on it in 4WD. Snow covered roads.
  5. Feb 21, 2010 at 4:39 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Where you in H4 or L4?
    TRAC in H4 and A-TRAC in L4 (if you have an Off Road TRD and it's activated) uses the brakes to achieve LSD (Limited Slip Differential action)... If over worked, that may smell... although mine never has.
    Was the VSC buzzer or any buzzer going off while you were four wheeling? The owners manuel warns that brake over heating can occur and a buzzer will alert you to let them cool off.
  6. Feb 21, 2010 at 4:41 PM
    MachoTaco10
    Nick
    New Hampshire
    did you just recently start smelling this burning? or did you smell it a while ago after being in 4wd? If you are going over 40 mph in 4wd that transfer case starts to scream and builds up a lot of heat. I know it says in the manual you can go a certain speed (I think 55) in 4wd high but the reality is no part time 4wd system is made to go extended periods of time or at speeds greater than 30 for an extended periods of time.
    How far and how fast are you going in 4wd?
  7. Feb 21, 2010 at 4:46 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I vote the cat converter burning off road crap that splashed up on it. The smell can get pretty nasty at times.
  8. Feb 21, 2010 at 4:52 PM
    MachoTaco10
    Nick
    New Hampshire
    na, he would notice that more often. hes only noticing this after being in 4wd
  9. Feb 21, 2010 at 5:00 PM
    Juicifer
    Probably going between 35-50mph in 4H, but I didn't hear the brakes working or see the traction warning come on. Maybe it was coming on really lightly for the drive I didn't hear it? I really wasn't slipping much.
    I always thought I could cruise at highway speed in 4H as long as I was going slow and off the gas when I engaged it. I did thousands of miles in my s10 at 65mph and not one problem. I hope I can expect more out of my Tacoma.
    Maybe it was the breaks just lightly working the LSD for miles but not enough for me to hear or feel it. Maybe I need some kind of T-case oil cooler.
  10. Feb 22, 2010 at 12:34 PM
    lrak
    lrak Well-Known Member
    You can. I have and never got a hot smell from anything. Just engage below 60mph and off the gas like you are. I try to disengage it before tight parking lot turns unless it is real slippery, but that's to make turning easier and limit stress on my CV/U joints. The gears in the front diff and transfer case are spinning all the time. Meshing the gears together (engaging 4x4) isn't going to generate that much more heat.
  11. Feb 22, 2010 at 12:41 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I've gotten this smell when driving a lot in snow in 4wd (obviously, I'm not driving fast if I'm in snow in 4wd). And I've also smelled it on every other vehicle I've ever driven in the snow. I agree that it must have something to do with the snow splashing up on either the engine or exhaust parts. Totally normal IMO.
  12. Feb 22, 2010 at 1:00 PM
    David K
    I don't think so... as we Tacomas have auto locking hubs, the front end drivetrain should be disengaged when in 2WD... at least that is what I thought... and I am on my third Tacoma with the auto hub feature.
  13. Feb 22, 2010 at 1:07 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I experienced the same thing when my truck was new. The overflow for the front diff oil pukes on the headers...my thoughts are its overfilled from the factory and a few drop overheat out. Been fine ever since.
  14. Feb 22, 2010 at 1:26 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    They do as only one side gets disconnected and other side still have connection between CV and diff so as you drive cv turns and that turns gears in diff and sends limited low turn into the driveshaft. And thats not bad thing because everything gets lubricated even if not in use :)
  15. Feb 22, 2010 at 2:59 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    That or grease from the front driveshaft gets slug onto exhaust.
    Its a 4wd truck, i have driven days without taking it out of 4wd with all the snow we have been having. If its a still a concern, just monitor the truck for any additional signs, but i think your fine.
