Burned Foglight
Discussion in 'Lighting' started by I Liquid I, Oct 8, 2010.
  1. Oct 8, 2010 at 11:08 PM
    I Liquid I
    I Liquid I [OP] Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    So I changed my bulbs a bit ago. For some unknown imbecilic reason I decided to try those cheap ebay bulbs for my fogs, since I dont really need them that much. They are supposedly "Xenon HID 100w 12v 5000k color temperature" bulbs. Anyhow, I just wanted to see how they looked.
    To my surprise, they light pretty damn good for not being a real HID... I decided to drive with them all the time at night, because IM COOL LIKE THAT!
    About 1 month later I see my driver's side foglight with white stuff inside. I though it was fogging up. When I took it out I saw it was getting burned from the inside out. :(
    Apart from the obvious change of fog housing... do you all really thing these flimsy bulbs couldve done this and that I should change them?
  2. Oct 9, 2010 at 9:23 AM
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    5000 K runs pretty hot. You dont get that amount of lumens on the road with out having an enclosure that vents the heat. I would get those suckers out of there, repair the damage and move on.
    Editorial comment: I grew up driving and racing European sports cars and back then fog lights and driving lights were exactly that- not a fashion statement for main street cruisers; they were on when needed and off when not. OEM "fog" and "driving" lights on todays vehicles are, with few exceptions, a product of the Marketing Department.
    If you want some, get a function designed product that actual engineers have produced.
  3. Oct 9, 2010 at 9:28 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    IIRC the OEM fogs are 45w, try and stay in that range. 100w will definitely burn the socket and melt the housing.
  4. Oct 9, 2010 at 9:29 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  5. Oct 11, 2010 at 3:07 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    +1 it has nothing to do with the light output, it's the wattage that determines how much heat they give off.
    For example, 35W HID's given a lot more light output than the 55W headlights, but they actually run cooler than the stock headlights.
  6. Oct 11, 2010 at 3:14 PM
    Asgard
    FWIW the stock fogs light output is 4000k
  7. Oct 11, 2010 at 5:07 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    5000K is the color, not the actual temp of the bulb...
    Get some 43-45 watt bulbs.
  8. Oct 11, 2010 at 5:17 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    fogs=35 watt HID's FTW
  9. Oct 11, 2010 at 10:12 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Did you touch the bulb with your bare hands when installing?
  10. Oct 11, 2010 at 10:46 PM
    I Liquid I
    Puerto Rico
    Sorry for taking so long to reply.
    No I did not touch bulb, else it could explode or whatever do to finger grease or whatever. :confused:
    I havent changed the bulbs yet. The fog light is done for anyhow, not like I can repair that, even worse when its inside. Ive checked my other fog and my headlights. There is nothing on them. I touch them (the plastic) and its not that hot. Sow for now imma keep running them I think, or I might just change all my bulbs into HID or something.
    TY to you all for the help. I need to check that about the 45w so that I dont mess up my Taco... which was flawless in the front till this happened... now I cant stop looking at it... :mad:
