Burned out clutch. Any recommendations on a replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Maximos Tacos, Feb 20, 2015.
  1. Feb 20, 2015 at 8:02 AM
    Maximos Tacos
    Maximos Tacos [OP] Member
    Maximo
    El Paso, Texas
    TACO'S RULE!
    Bilstein 5100's adjusted at 2.5 - Downsouth Motorsports, Energy Suspension Parts sway bar and end link bushings, Energy Suspension Parts front coil spring isolators, front shock replacement bushing/washer -Toytec Lifts, solid steel axle degree shims - Toytec Lifts, front Differential Drop Kit - Toytec Lifts, Urethane complete Rear Spring Bushing Kit - Toytec Lifts, ICON 1.5" add-a-leaf - Downsouth Motorsports, 4.11 gears-East Coast Gear Supply, New black front and rear bumpers, Carr Low Profile light bar, Pro-comp lights
    I have a 1995 Tacoma 4x4 2.7l. Burned out my clutch and need recommendations for a replacement. Should I get a performance clutch like a Centerforce or stick with Aisin which is the oem brand. I like the technology Centerforce has but is it all hype, I mean do I really need a performance clutch opposed to the oem clutch? My truck has a new engine(stock), new suspension (Bilseins and addaleaf), new brakes, new tires, new gears(4.10s), dang all I need is a new transmission and I'm good...lol. Ok, but really, can someone advise me?
    Thanks.
  2. Feb 20, 2015 at 11:16 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    A lot of guys go with the marlin crawler clutch. It may be over kill but check em out, you may be sold on em?? I pry don't need anything other than an OEM clutch since its lasted 200k and still going. But its getting weak, when it goes I'm gunna get the crawler set up. I believe they have two different options for our trucks too.
  3. Feb 20, 2015 at 7:11 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    I installed an Aisin clutch, pressure plate and an aftermarket flywheel in my 2000 Tacoma 3.4L 4x4 with a new release and throwout bearing. It's been great. Very light pedal pressure, good engagement, smooth and no noises. I bought a clutch kit off of eBay that came with everything I needed but I made sure it was Aisin parts. I considered the Marlin Crawler clutch but it was out of stock. I have no regrets.
  4. Feb 20, 2015 at 8:00 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  5. Feb 21, 2015 at 4:01 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Same with me. I also wanted the Marlin kit but they told me it was out of stock with no eta. So i ordered a Aisin kit, i got mine from Rockauto. Also no regrets.
