Burned running light lens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ebrame, Dec 10, 2012.
  1. Dec 10, 2012 at 9:15 AM
    ebrame
    ebrame [OP] New Member
    I have aa 2009 Tacoma access cab SR5. The lens on both running lights have burned and cracked. I called the dealer and they basically said "that's tough, you have to replace the entire headlight assembly on both sides".
    Has anybody else had this problem and is there a less costly fix?
  2. Dec 10, 2012 at 9:16 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    autoanything.com has them but if you have to buy new ones I would do the BHLM while your at it if you were wanting to do it...
  3. Dec 10, 2012 at 9:19 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Pretty common problem from what I read, and if your out if warranty, then IIRC, your on your own.
  4. Sep 30, 2014 at 7:26 PM
    shawee
    shawee Member
    Shawee
    Los Angeles
    Pre Runner
    Both of my daylight/running light are cracked and separated, and when I brought it to the dealer after 3 years they told me that maybe you replace the bulb with high wattage bulb, which I did not... I can't do anything but to save for replacement.
  5. Sep 30, 2014 at 7:27 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i got a recall notice about it. never had an issue though
  6. Sep 30, 2014 at 8:09 PM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    There's a thread in the Lighting Forum regarding the recall. Lots of guys having success getting new headlights. That piece is replaced with a glass piece.
  7. Oct 2, 2015 at 4:42 PM
    shawee
    shawee Member
    Shawee
    Los Angeles
    Pre Runner
    they send me an extended manufacturers warranty, and just got it replaced from the dealer, thanks
