burned through the clear coat
Discussion in 'Detailing' started by alexander323bc, Sep 27, 2011.
  1. Sep 27, 2011 at 6:21 AM
    alexander323bc
    alexander323bc [OP] Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Pretty sure I burned the clear coat with a 2000 grit piece of sandpaper in about 7 strokes trying to smooth out some touch up paint. Now I have an estimated $700.00 repair bill. Can I just put touchup back on the spot and put clear coat on top it then sand it down?
  2. Sep 27, 2011 at 11:12 AM
    mwtaco
    mwtaco Well-Known Member
    07DCSB Black
    if your not sure why dont you get some compound and work it in with buffer or elbow grease followed by a polish. 7 strokes seems not enough to cause major damage. post a pic.
  3. Sep 27, 2011 at 11:43 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Take a towel and some polish and rub on the spot where you sanded. If you get paint on your towel the color of your truck, your clear coat is compromised. If not use the polish to remove the sanding scratches.
  4. Sep 27, 2011 at 12:26 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    ok guys thanks for the info. The paint place said I burned through it because it had a very very thin clear coat. I will try the towel method when I get home. I really cant believe this is happening :( that was 700 towards my wheels and tires!
  5. Sep 27, 2011 at 4:21 PM
    mwtaco
    07DCSB Black
    good luck. hopefully it polishes out. seems unlikely 7 strikes would cut thru clear coat. let us know.
  6. Sep 27, 2011 at 4:23 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    02 PreRunner DoubleCab TRD
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    How big is the spot? You can get touch up clear coat to touch it up. (You will have to sand that down after it is dry, but if you are carefull it will be okay)
  7. Sep 27, 2011 at 7:25 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Boerseun its a pretty big spot and that is what I did today I put clear coat on it and its now drying going to sand it down tomorrow and see where I am at. It cant really look any worse at this point. Just trying to make it look like something that is reasonable that people arn't going to stare at. I will try to get some pics of it tomorrow
