Burned truck, opinions ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacobienhecho, Feb 1, 2018.
  1. Feb 1, 2018 at 7:55 PM
    #41
    tacobienhecho
    tacobienhecho [OP] Well-Known Member
    silver 4/4
    Thanks man. I had just finished paying it off too. It took a lot to do as those funds came from when working and going to school.
  2. Feb 1, 2018 at 7:55 PM
    #42
    Muddinfun
    Muddinfun Well-Known Member
    Comprehensive insurance is only about $15 per year. Would have paid for his truck.
  3. Feb 1, 2018 at 8:55 PM
    #43
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Very little more money between full and part coverage,at state farm its like $20 more a month and well worth it as you just learned.
  4. Feb 1, 2018 at 9:08 PM
    #44
    tacobienhecho
    silver 4/4
    Yeah you guys are right. I had just finished paying it off and figured id recover from the things i had gotten the truck. looks like it backfired
  5. Feb 1, 2018 at 9:13 PM
    #45
    Muddinfun
    You don't even have to have full coverage to add comp. Like I mentioned, I have 4 vehicles with comp only on them. If a tree falls on them, they catch fire or they're stolen, they're covered.
  6. Feb 1, 2018 at 9:18 PM
    #46
    tcjacado
    tcjacado Well-Known Member
    The spiral cable in the steering column was on recall on my 07 and that was a fire hazard according to the recall notice I recieved. Sorry for your loss op.
  7. Feb 1, 2018 at 9:19 PM
    #47
    oldglorytaco
    oldglorytaco Member
    Rough day. Try to move on as best you can.
    tacobienhecho[OP] likes this.
  8. Feb 1, 2018 at 10:07 PM
    #48
    tacobienhecho
    silver 4/4
    You live and you learn. Thanks though. Must have for future vehicles. Funniest thing though. If i remember correctly, the guy that sold me the UCA and coilovers also said his truck caught fire after installing them.
  9. Feb 1, 2018 at 10:45 PM
    #49
    Muddinfun
    I'm gonna take a shot in the dark here. When you removed the UCA bolt you bent the inner apron out of the way. Somehow the positive battery cable, that goes to the starter, ended up against sharp metal or hot exhaust and the insulation wore/melted through.
  10. Feb 1, 2018 at 10:49 PM
    #50
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Those are not even remotely close to each other. Starter cable runs right along side the motor down to the starter. Uca bolt is right above the frame.
    Not to mention the starter cable is full shielded in loom
  11. Feb 1, 2018 at 10:50 PM
    #51
    tacobienhecho
    silver 4/4
    I
    When i installed the UCA i did so, as they show that on total chaos's install video. I was also careful when it came to biting the cables that ran on that side of the apron. I also made sure that when i rebent kr bent the apron back , i didnt leave any sharo edges or bend marks for thst reason. But ill check that as well. Thanks
  12. Feb 1, 2018 at 11:10 PM
    #52
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    Looks like the end housing from a winch, was there a winch on the truck?
  13. Feb 1, 2018 at 11:12 PM
    #53
    tacobienhecho
    silver 4/4
    Sorry guys i didnt mention it. Thats thr wheel cap for a set of alloys i had on the truck
  14. Feb 1, 2018 at 11:45 PM
    #54
    Muddinfun
    OK, sounds like you were real careful with everything. Gonna be real hard to determine the cause of the fire.
  15. Feb 2, 2018 at 3:52 AM
    #55
    ChesterT
    ChesterT Active Member
    Rochester, NY
    2015 DCSB
    If it burned in your driveway, try your homeowners ins. agent. See if they have anything to offer.
  16. Feb 2, 2018 at 6:12 AM
    #56
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't see the issue of using a torch to loosen the CAM Bolts. Shops and individuals do this all the time. I really wouldn't think that it simmered after it was broken loose and the tech was right there doing the alignment and re-tightening all the bolts etc afterwards and didn't see anything. Then it sat while his brother paid and then the magic fire continued to simmer all the way home until parked in the driveway and then it caught and blazed out.
    Sorry, I don't think that theory holds water.
    As said above check your home owners policy.
    Chris24, DoorDing, Red Baron and 8 others like this.
  17. Feb 2, 2018 at 6:33 AM
    #57
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I know nothing about fire science but it appears the battery got the hottest looking at the carnage. Perhaps just a freak accident. So sorry for your loss hope you get taken care of at least no one got hurt.
  18. Feb 2, 2018 at 8:32 AM
    #58
    81shark
    81shark Well-Known Member
    from what i see, it's unlikely that the homeowners policy will pay for it...
  19. Feb 2, 2018 at 8:39 AM
    #59
    lynyrd3
    Bill
    East Central Upstate NY
    :eek:
  20. Feb 2, 2018 at 8:44 AM
    #60
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Total bummer man. It's a long shot but I would pull the homeowners insurance or call you agent and see if there is anything that can be done.
    Also , just to dot the i's, are you sure you dont have comprehensive auto insurance?
