Burning 6qt of oil between changes
Discussion in '4 Cylinder' started by windwalking, Feb 27, 2017.
  1. Mar 1, 2017 at 7:34 AM
    windwalking
    windwalking [OP] New Member
    2007 4 cylinder 2WD Tacoma Prerunner Manual Regular cab
    3" bilstien suspension lift front and rear sway bars
    I spent all day detailing under the hood, undercarriage and inside /out.
    Not a drop of oil anywhere. Just very little road grime in oil pan. No oil puddles. No liquid marks anywhere. Nothing. It's sitting in the garage so haven't driven it to determine any leaks/oil consumption.
    The rattling sound concerns me. It did go away.
    When it rattled, it was loud just like a flywheel on a bicycle, every time letting off gas pedal wether in 1st gear or 5th gear and remember I drive high RPM. The rattle completely gone when I stepped on gas pedal to accelerate.
    So I want to know what caused the rattle in the first place? And what kind of damage? I drove it about 500mi before I could take it into the half quart mechanic.
    My best guess is the flywheel, bearings need greased and/or replaced? That's what my ears and gut tells me.
    My clutch doesn't slip. I don't know why adding oil would make it go away. And again where did the oil go in the first place?
    I'd trust my Amsoil mechanic any day over half quart guy. He was at a dealership, maybe trying to work me with the sales team to trading in my truck for a payment. I take care of my Tacoma and believe I can take it to 400k. Already owned one that had 1986 FJ60 385k original block.
    Time will tell if it burns oil or need a new flywheel, valve seals, piston rings, drive shaft??? At 227k my Tacoma has never failed me and ran smooth / perfect except this one rattle. Maybe rattlesnake crawled up in there when I was desert camping ☺️
    Thanks to all.... Nobody's touching my truck!
  2. Mar 1, 2017 at 7:37 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    id say go ahead and replace or grease the flywheel if that's your gut instinct. itll at least give you peace of mind until it happens again (which it may not!)
  3. Mar 1, 2017 at 7:37 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Do you check the oil in those 7500 miles?
    I check it every fill up for this very simple reason...
    Toyko Joe and Clearwater Bill like this.
  4. Mar 1, 2017 at 7:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    What kind of grease? The whole face of the flywheel, or just the toothed edge? What about those with autos that don't have flywheels? Should we lube the flex plate? So many questions.
  5. Mar 1, 2017 at 7:41 AM
    jpneely
    Charleston, SC
    no idea. never touched a flywheel, but if replacing it gives peace of mind, I say go for it.
  6. Mar 1, 2017 at 7:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Well, I figured it was either that or you were joking, and I was willing to play your straight man.
    My apologies for guessing wrong. :hattip:
  7. Mar 1, 2017 at 7:48 AM
    jpneely
    Charleston, SC
    haha no worries.
  8. Mar 3, 2017 at 8:00 AM
    tgear.shead
    tgear.shead Well-Known Member
    There are quite a significant number of things on a truck that can make a rattle sound. VERY common, is the exhaust heat shields. That rattle might not have had ANYTHING to do with the engine.
    I'd suggest that you do this;
    1) monitor the oil level frequently until you are confident that it isn't consuming oil at an excessively high rate.
    2) after a few thousand miles, take a sample of oil and send it in for analysis. The guys at blackstone can tell you if the engine has been severely damaged by checking the properties of the oil.
    Now about the loss of oil...
    Oil doesn't necessarily disappear by leaking out. If it was doing that, you PROBABLY would notice a pool of oil on the ground. However, oil loss past the rings or through the crankcase vent will be burned through the engine. Normally, vehicles that have been having this kind of problem for a very long time will blow a lot of blue smoke out the tail pipe, HOWEVER, if a problem just formed recently and the catalytic converter is still working, then the oil may be burning fairly efficiently in the exhaust system.
    Toyko Joe likes this.
  9. Mar 6, 2017 at 6:25 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Holy crap batman. I have oil evaporation issues and elevated consumption thanks to 195k of hard use but I have always changed my own oil and never have I drained half a quart. I'd keep an eye on it for sure.
    Smell your oil and open the oil fill cap and take a good whiff. If you smell gasoline you have injector leakage. Gasoline in the oil equals faster oil evaporation.
  10. Mar 6, 2017 at 6:35 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Compression leak down test would give indication of rings or valves. Valve stem seals would be my best guess.
    2.7taco likes this.
  11. Mar 7, 2017 at 11:22 AM
    uwu
    uwu Well-Known Member
    Brain? :p
  12. Apr 1, 2017 at 10:36 PM
    Glamisman
    Glamisman Well-Known Member
    if it is as you described above I would check the crankshaft end play... a couple of screwdrivers on the crank pulley and pry forward slightly then push back and see how much it moves... shouldn't be very much at all, a few thousandths... if it clunks, you have found the problem.
  13. Apr 5, 2017 at 7:48 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    :rofl::rofl:
  14. Apr 24, 2017 at 9:24 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    This is an amazing thread.
    1/2 qt. oil drained and the thing runs.
    Somebody was not watching the oil level on the dipstick.
