Burning a quart of oil weekly , no visible leaks .. Need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyfam209, Sep 26, 2016.
  1. Sep 26, 2016 at 8:26 AM
    Toyfam209
    Toyfam209 [OP] Member
    '00 taco manual 4x4 TRD
    Hello you guys need help with my taco 2000 5 speed Manual 4x4 Trd .
    Has 327k original engine
    Bout a couple weeks ago my engine started idling around 1800-2000rpm at cold start or even hot days
    And then after a camping trip I check my oil it's below the first mark
    So I added some conventional oil and drove it around and check it again and it's back below the first marker .. Been adding oil and still having the same issue ! Please help .. Hope it's not a blown h g ..thanks in advance .. (New air filter, plugs was done 6months ago , gapped also . )
  2. Sep 26, 2016 at 8:33 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    probably valve/head problems not necessarily head gasket unless you have oil in your radiator or coolant in your oil.
  3. Sep 26, 2016 at 12:47 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You might want to do a compression test of the cylinders and rings. With that much mileage you might be getting substantial blowby, though I'd think with burning that much oil you'd see some smoke. These engines regularly get past that mileage without heavy oil consumption issues, as long as the oil was changed somewhat regularly.
