Burning Oil after Head Gasket Replacement (5VZ-FE)
Discussion in 'Technical Chat' started by calvainiac, Jan 23, 2023.
  1. Jan 23, 2023 at 4:13 PM
    calvainiac
    calvainiac [OP] Member
    2001 Tan Tacoma TRD
    I recently had the head gasket and spark plugs replaced on my 2001 V6 Tacoma by a licensed mechanic. It was burning oil, about a quart or so, between oil changes (5K miles) before getting the gasket replaced.
    It has been about a month or so since I had it replaced and I checked the oil today and it was once again on the low dot on the dipstick. I also noticed that the coolant reservoir was low and that is not typical for my truck.
    Would anyone know an issue that would cause this? I am wondering if the water pump may be going bad now too or somehow the coolant is getting somewhere it shouldn't be? The exhaust doesn't smell sweet and there was no coolant on my dipstick so I am pretty confused.
    Thanks!
  2. Jan 23, 2023 at 4:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did they do both head gaskets or just one side?
    You said it was burning oil before the job? A head gasket typically has nothing to do with oil consumption.
    A faulty PCV valve can cause oil consumption, it would be a cheap/easy thing to change just to rule it out but in most cases oil consumption is caused by worn or carboned up/stuck piston rings or leaking valve stem seals.
    Any visible external leaks, coolant or oil?
    Bivouac likes this.
  3. Jan 23, 2023 at 4:55 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Why don't you take it back to the licensed mechanic? They should be able to tell you pretty quickly if the head gasket job was not done well or it failed again.
  4. Jan 23, 2023 at 5:03 PM
    calvainiac
    2001 Tan Tacoma TRD
    Thanks for the replies guys.
    Jason - That is one of the issues I am having. I am drastically losing confidence in this shop and I am not sure if they would even try to resolve the issue.
    Dm93 - Thank you for the tips, I will check and replace the PCV valve this week. The only reason I thought that the gasket would be related is because it would also visibly leak from them as well before replacement. There are also no visible leaks of any kind.
    Dm93 likes this.
  5. Jan 23, 2023 at 5:05 PM
    Bishop84
    Bishop84 Well-Known Member
    If they did a head machined, the valve seals were changed and it possible one is leaking.
    As for coolant its hard to say, top it up and see if it drops.
    Dm93 likes this.
  6. Jan 23, 2023 at 5:06 PM
    nickrick78
    nickrick78 Well-Known Member
    Nick
    Pittsburgh PA
    Tacoless for now
    PCV would be a cheap, quick thing to try. Oil burning is usually piston rings, sometimes valve seals, but usually not head gaskets.
    Dm93 likes this.
  7. Jan 23, 2023 at 5:13 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Make sure all the PCV lines are routed properly, it's pretty straight forward but you never know.
  8. Jan 23, 2023 at 11:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Perhaps the coolant level was never topped off.
    Bad radiator Cap?
    Smelling any coolant in the cab Heater cores like to leak just to be mean.
    Pressure test cooling system for the peace of mind.
  9. Jan 23, 2023 at 11:35 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    How many miles on your motor?
    Cylinder wall wear. The thrust surface of the piston riding on the cylinder wall wore off the cross hatch.
    Ghetto repair. Pull cylinder heads drop the oil pan and hone the cyl walls
  10. Jan 23, 2023 at 11:43 PM
    Bivouac
    Doing all that work to remove the oil pan just pull the engine.
  11. Jan 24, 2023 at 12:02 AM
    tw0leftskis
    0xApes
    Meta Verse
    Thats why I asked how many miles on Engine.
    If it's low miles and the walls are not tapered. Really no reason to pull the engine.
    The "Mechanic" should have checked the cylinder wall for wear before slapping the heads back on.
  12. Jan 24, 2023 at 12:33 AM
    Bivouac
    I will pull the engine before the oil pan.
    What ever the reason .
  13. Jan 24, 2023 at 1:28 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Pull the plugs one by one and look in the cylinders with a camera at the rings and cylinder walls like someone said .
    You never told us the mileage ?
