Burning Oil? Drained less than put in
Discussion in '4 Cylinder' started by Dustyroades, Apr 24, 2013.
  1. Apr 24, 2013 at 9:37 PM
    Dustyroades
    Dustyroades [OP] Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    I have an '09 Tacoma with 91,000km on it. Yesterday when I did an oil change (after 8,000km with no top-ups), I noticed that I drained out approximately 0.7 litres/quarts less than I put in. I dumped the filter into the drain pan and let it mostly drain out, so I don't think it was holding much. So my question is, does the 2TR-FE block and oil system hold ~1/2 a quart you can't get out easily, or am I burning oil?
  2. Apr 25, 2013 at 5:18 AM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    All engines use some oil over the course of use. There is also no possible way besides a tear down to get all the oil you put in back out. I've drained as much as 4 1/2 qts after my first change after the factory fill. Yours seems very normal, so carry on. I'm also pretty sure that it takes 1/2 qt of oil just to coat the engine.
  3. Apr 25, 2013 at 11:09 AM
    Dustyroades
    Ontario
    OK cool, thanks for the reply.
  4. Apr 25, 2013 at 9:04 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Where was it on the stick before draining? I always check that just for reference. (Actually, I also check at least every 500 miles.) As long as it doesn't pass below that bottom mark, you're golden.
    x2 that it's impossible for a piston engine to not use at least a small amount of oil. Toyota says anything less than a quart in 600 miles is acceptable. Fortunately for us their motors tend to be FAR more frugal.
  5. Apr 25, 2013 at 9:36 PM
    Dustyroades
    Ontario
    It was about halfway between the marks on the dipstick before draining. That being said there has been discussion on this site about the dipstick marks being incorrect on the 4 cylinder.
    I find the dipstick quite difficult to read as it always smears on the way up the tube. When the oil is new synthetic, it's nearly impossible for me to get a reliable reading.
