Burning Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pugga, Apr 2, 2012.
  1. Apr 2, 2012 at 6:48 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I never had an issue of burning oil until I owned a Honda.
  2. Apr 2, 2012 at 6:51 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Or PCV valve sucking oil into the cylinders. #6 spark plug is always oily due to that stupid crankcase vent over it. .
  3. Apr 2, 2012 at 6:56 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    As BlueT mentioned, replace, not just inspect the PCV valve.
  4. Apr 2, 2012 at 6:57 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    You have to be careful buying oil. I have seen the Mobil 1 in 5 quart and 4 quart size jugs for just about the same price. Did you use quart size bottles or is there a chance you think you bought the 5 quart jug and really only bought the 4 quart; and then added an additional half thinking you had just filled with 5.5 but really only filled with 4.5?
  5. Apr 2, 2012 at 6:59 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
  6. Apr 2, 2012 at 7:03 PM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I usually buy the 5+ jugs which are 5.28 qts. I don't have the old jug so I suppose it's a possibility. Like I said, I'm really hoping it's just a series of brain farts so that's not a bad suggestion.
  7. Apr 2, 2012 at 7:10 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    To check if its the guides, downshift and let the engine slow you down going down the hill then when almost at the bottom, hit the gas, if there is a problem with the guides you will see a puff of blue smoke. Cheap way to see if its the guides.
  8. Apr 2, 2012 at 7:25 PM
    Night
    Canada
    Do you down shift to force engine braking? Then accelerate once you're at the bottom?
  9. Apr 2, 2012 at 7:53 PM
    Night
    Canada
    I agree. Just went accelerating though. Find a straight hill? Haha
  10. Apr 2, 2012 at 8:09 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    damn...i was about to use Mobil 1 on my next oil change i guess i'll just stick with prestone. this thread is making my truck nervous
  11. Apr 2, 2012 at 8:13 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I switched a truck over to Mobile 1 at 35K or so. It went from no oil loss in 3K miles to using a half a quart every 2K. That really didn't bother me, so I let it go. After the rear main seal started leaking, I went back to dino. Never burned another drop after that. The rear main stopped leaking too.
  12. Apr 2, 2012 at 8:54 PM
    Night
    Canada
    Correct me if I'm wrong but isn't Dino the OEM fluid sort deal? I sounds familiar. But maybe the cohesion/adhesion properties of some oils have something to do with the metal our engines our made of.
  13. Apr 2, 2012 at 9:49 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you want to monitor oil level and consumption, use the dipstick on level ground. Measuring drained oil is not a very accurate measure of oil consumption. Even a drained filter holds a fair bit of oil, even one our size. Did you use one of the larger filter options this tine perhaps?
  14. Apr 2, 2012 at 10:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    when the valve guides are worn they allow oil to drain down the stems into the intake tract. When you start the truck up that oil goes straight into the cylinder and burns.
  15. Apr 3, 2012 at 3:50 AM
    #35
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    Yup, might as well stick with that Prestone. Your engine is already toast.:D
  16. Apr 3, 2012 at 4:52 AM
    #36
    Pugga
    Massachusetts
    Worth a shot! :thumbsup:
    Hmmm... If I lose the same amount this oil change, I might switch back to dino just for shits and grins and see what happens.
    I agree 100%. That's why I'm not overly concerned yet. I've been checking the oil using the dipstick every morning and will continue to do so for the next few thousand miles. Measuring the oil you get out of an engine isn't the best way to tell if you've lost oil but it's a good way to catch your attention so you can catch something before it becomes a big problem. I use the same Toyota OEM filters everytime. I buy 2 - 3 at a time so the same size filter.
    So I'm assuming that's what is going on with Whipper's truck, giving him that nice blue smoke at start up. I watched this morning, I'm not showing any smoke at startup, just a very fine, white vapor after it's been running for a few seconds. No blue hues!
  17. Apr 3, 2012 at 6:34 AM
    #37
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well it could also be the PCV valve which is actually more likely than the valve guides on a <100k mile truck.
  18. Apr 3, 2012 at 8:10 AM
    #38
    Watari06V6
    Wounded Knee
    TRD-V6-SR5-06
    Pennzoil! sorry it was late when i logged in :p
  19. Apr 3, 2012 at 8:41 AM
    #39
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    no doubt about that
