Burning Rubber/Oil Smell from engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elwood blues, Apr 26, 2010.
  1. Apr 26, 2010 at 4:11 PM
    elwood blues
    elwood blues [OP] Member
    Oregon
    4 Cyl
    I purchased my Tacoma in September 2009. Automatic transmission. I have 1,300 miles on it. It still has a strange burning rubber smell from the engine area after driving it. There is no visible smoke. I had it looked at at the Toyota Dealership where I purchased it. They couldn't find anything wrong (such as a plastic bag caught in the engine area). The only comparison I can make is the smell after an oil change (spilled oil on the manifold during oil change). I know I don't have that many miles, but after 7 months, should it still smell that way? The oil is still from the day the factory installed it. Synthetic oil. :confused:
  2. Apr 27, 2010 at 2:43 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Make sure the filter is tight. This is the only thing I can think of that is near the exhaust.
  3. Apr 27, 2010 at 4:40 PM
    elwood blues
    Oregon
    4 Cyl
    Thanks, I will.
  4. Apr 27, 2010 at 5:19 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    if oil is hitting the exhaust or engine, you should be losing some or at least be able to see some drops somewhere. It could be hitting the cross pipe under neath by transfer case. Check under there as well.
  5. Apr 27, 2010 at 5:28 PM
    spp
    spp OC, Kalifornia
    OC California
    7 months and only 1300 miles is the problem.:eek:
    I bought mine around the same time and had that many miles in less than a month.;)
    I remember it took a little over a month for any burn in smells to go away.
    Take that thing out and get it warmed up!:D
  6. Apr 28, 2010 at 1:18 AM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    my tranny makes that smell
  7. May 9, 2010 at 5:39 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Don't know, are you sure it isn't the new engine smell??? My Nissan 370Z produced a simlar smell well into 3200 miles....
  8. May 9, 2010 at 7:12 PM
    2.7taco
    Texas
    If you smell that from your trans you are burning clutch material.
  9. May 9, 2010 at 7:16 PM
    2.7taco
    Texas
    Just a thought but the trans check the trans fluid level if your low you may be burning your clutches.
  10. May 9, 2010 at 8:00 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Good luck checking the tranny fluid
  11. May 9, 2010 at 8:31 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    The burning smell is because your engine is still new. Every new car/truck does this. It's a coating on the engine parts that keep them clean until you take delivery of your new vehicle. That way if the vehicle sits on the lot for 6 months the engine doesn't get all rusty and seized up. Just drive it and eventually it will go away. Sometimes I get used cars where I work that have 13,000 miles and they still make the smell. Don't worry, unless you see smoke coming from under the hood.:D
  12. May 9, 2010 at 8:39 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    only time i get a nasty smell like that is from mud
