Burning smell w/ oem rotor and pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike06toyota, Aug 21, 2017.
  1. Aug 21, 2017 at 12:48 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    if the truck pulls to one side when braking then maybe its a caliper sticking
  2. Aug 21, 2017 at 12:49 PM
    Mike06toyota
    Mike06toyota [OP] Well-Known Member
    Santa Clarita
    06 PreRunner TRD Sport
    K&N Intake Flow Master
    It does not it stays pretty consistent through out
  3. Aug 21, 2017 at 12:52 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    It's what your wheels are bolted to.
  4. Aug 21, 2017 at 12:53 PM
    Mike06toyota
    Santa Clarita
    Could I be smelling something intermittently from there? What would other symptom be?
  5. Aug 21, 2017 at 12:57 PM
    Bebop
    Nick
    Play, roaring noise.
  6. Aug 21, 2017 at 3:38 PM
    Mike06toyota
    Santa Clarita
    Is there anything between the brake pad and the piston from the caliper? I don't have anything between them. I have the oem setup
  7. Aug 21, 2017 at 4:20 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    Yes and no.
    If the piston is sticking, sometimes you can push it back and free it up for a short term fix. Rebuilding a caliper is preferred to retain the oem unit. As for overheating, you would have to get a rotor extremely hot "red hot" to form cementite and ruin the rotors and pads. A little smell is nothing to worry about, most new brakes need to be bedded and can produce a smell when driving the first few times.
  8. Aug 21, 2017 at 4:43 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  9. Aug 21, 2017 at 5:58 PM
    Mike06toyota
    Santa Clarita
    I took out the pads use the whole can of brake cleaner on each side and lubed those parts but we talked about. Right now the squeak is gone but the squeak was not there when I originally did it to begin with so I will check back in after a week or so
    Bebop likes this.
  10. Aug 21, 2017 at 6:42 PM
    Bebop
    Nick
    Rebuilding calipers is becoming a thing of the past. A lot of reman calipers use the Toyota housing and have a lifetime warranty. No brainer. Now a reman master you should stay away from.
