Burning Smell
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gfunk123, Mar 5, 2024.
  1. Mar 5, 2024 at 10:19 AM
    Gfunk123
    Gfunk123 [OP] Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    I had my UCAs replaced three weeks ago and was getting a burning smell come from the driver side area near the battery immediately after this work. I assume it was just penetrating oil burning off at first. After 3 days of driving it I took it back to shop. Owner couldn’t figure out where the smell was coming from and tech suggested penetrating oil. Well 3 weeks later it still has a smell. Any idea what it could be??? I’m stumped.
  2. Mar 5, 2024 at 12:35 PM
    Waasheem
    Waasheem
    2007 xrunner
    It’s possible they were careless spraying penetrant. But it should have burned off after one or two drives.
    You should look at the battery cables too, in case.
    Also make sure the alternator isn’t cooking the battery, over charging.
    Gfunk123[OP] likes this.
  3. Mar 5, 2024 at 12:41 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Is it a burning rubber, plastic, or electrical smell. They are all different. This may help narrow things a bit.
  4. Mar 5, 2024 at 6:44 PM
    Gfunk123
    '13 limited taco
    Maybe a plastic smell. Doesn’t smell electrical or like rubber. I’ll take it to advance auto and get an alternator test done.
  5. Mar 5, 2024 at 9:37 PM
    Waasheem
    Waasheem
    2007 xrunner
    Plastic smell could mean something rubbing on a pulley or the belt. That should make some sort of sound. Or something resting on the exhaust pipe or manifold.
    I don’t think the alternator would cause a plastic smell.
    Look under the hood. Look at the belt and everything it touches. Look at the exhaust manifold and pipes. Look for wisps of smoke.
  6. Mar 5, 2024 at 10:02 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Check wheel wells to see if anything is rubbing on the tires. Maybe lift front end and free spin the wheels.
  7. Mar 7, 2024 at 6:21 AM
    Gfunk123
    '13 limited taco
    Thanks y’all. I’ve looked pretty hard but I’m going check again based on some of the above comments.
  8. Mar 7, 2024 at 7:02 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    There is a wiring harness just below the battery that clips to the frame of the truck. If the person who replaced the UCA didn't undo this clip, they probably damaged it when they removed the UCA bolt. I would remove the battery and take a look. It's hard to see if the battery is there.
