Burnt clutch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LeeVanChief, Oct 27, 2018.
  1. Oct 28, 2018 at 8:51 AM
    #41
    Tacoma Mike
    Southern Maine
    Man that is horrible however, your quick thinking possibly saved his life.
  2. Oct 28, 2018 at 8:58 AM
    #42
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Hey man,
    I doubt there's anything we can say to you, to make you feel better, but as others have said, you saved your friend's life. Everything leading up to that moment were mutual decisions. While it may feel like you pressured him to go a direction he didn't want to, ultimately he chose to go along. What happen happened, but your quick thinking and actions kept it from being worse. Your friend will appreciate having his life over his hand. And even more so, he will appreciate you and your actions.
    Hang in there man. You're not to blame for your buds accident... it's just that, an accident.
    tinker_troy, TD90S, Markcal and 5 others like this.
  3. Oct 28, 2018 at 9:01 AM
    #43
    pyankura
    pyankura Well-Known Member
    17 TRD SPORT QUICKSAND
    You did good dude, real freaking good! Things happen, not your fault, you both had no idea something like this would happen. You are a damn hero and should be commended!
    Someone make a go fund me for him and his buddy. I’ll pitch in...
    tonered and Bertw192 like this.
  4. Oct 28, 2018 at 9:05 AM
    #44
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    @LeeVanChief What do you mean by twice as much pressure? Is it harder to press or does the pedal sink farther before disengaging?
    Also, if end up replacing it check out URDs heavy flywheel too. Should make it easier to prevent stalling, less throttle needed to keep the rpms up in these situations.
  5. Oct 28, 2018 at 9:06 AM
    #45
    LeeVanChief
    LeeVanChief [OP] Well-Known Member
    2018 OR 6Speeeed Taco
    I appreciate everything, guys. I'm pretty sick and fucked up at the moment. It's not so much the gore but just the whole situation.
    specter208 and Bertw192 like this.
  6. Oct 28, 2018 at 9:08 AM
    #46
    LeeVanChief
    Just a heavier pedal. Everything else seemed normal ie. Diastance and where it engages. No slipping. I didn't drive it today
  7. Oct 28, 2018 at 9:10 AM
    #47
    T4RFTMFW
    T4RFTMFW Well-Known Member
  8. Oct 28, 2018 at 9:14 AM
    #48
    Tacoma Mike
    Southern Maine
    Should of ,could of, would of.
    You can twist this all around and make it your fault.
    You weren’t using the saw.
    What could have happened if someone that didn’t have the nuts to do what you did?
    No matter what is said or done down the road.
    You did good.
    MUCH RESPECT....
    ColoradoTJ and elduder like this.
  9. Oct 28, 2018 at 9:15 AM
    #49
    Caliph420
    Caliph420 Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    Sorry op my bad
  10. Oct 28, 2018 at 9:17 AM
    #50
    elduder
    Van WA
    Check the fluid reservoir, something may be blocked or screwed up from the heat on the hydraulic side. TOB may toast too.
  11. Oct 28, 2018 at 9:19 AM
    #51
    dirtyplumber
    dirtyplumber New Member
    Tyler
    2018 TRD OR DC
    Crazy Story! Thanks for being a stand up dude, we need more of them. I hope your friend gets better. Tooooyyyoootttaaa!
    LeeVanChief[OP] likes this.
  12. Oct 28, 2018 at 9:20 AM
    #52
    elduder
    Van WA
    Lol this video, I've seen it so many times. On a car with that much torque the clutch pedal shouldn't have been touched after the initial drop.
    jtmiller2011 likes this.
  13. Oct 28, 2018 at 9:22 AM
    #53
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Like the others have said you saved his life.Dwell on the fact it could have ended differently.Sounds like you did everything right.If he was stupid with the chainsaw that's on him but sounds like just a horrible accident.
  14. Oct 28, 2018 at 9:25 AM
    #54
    LeeVanChief
    I'm sorry, man. I may have overeacted. My head is all over the fucking place. idk
  15. Oct 28, 2018 at 9:27 AM
    #55
    Caliph420
    Washington
    No worries to be expected, poor taste on my part, best wishes on everything turning out better given a f'ed situation from here on out man, that had to be gnarly
  16. Oct 28, 2018 at 9:31 AM
    #56
    LeeVanChief
    That's pretty much what I was doing the whole way up. There was a lot more smoke that that. I was worried about fucking up catastrophically. The clutch wasn't even a thought. I didnt care as long as I made it to the top. One thing I can say for certain is I wouldn't have made it up without the lift.
    SnowroxKT and TeecoTaco like this.
  17. Oct 28, 2018 at 9:32 AM
    #57
    thdrduck
    thdrduck Well-Known Member
    First off, really sorry, that's some messed up shit. Maybe talk to someone, you know, professional. I know I would need to, I don't handle that kind of shit well that's why I'm not on the fire department. Best of luck to you.
    As far as your truck... things got really really hot and they don't handle that very well. I would plan on a complete clutch job to include, replace the clutch plate, pressure plate, throw out bearing and gear oil. If your flywheel is not too bad (expect hot spots) have it turned, if it can't be turned, replace that also. It sucks, but once you are in there if you fail to do any of that, you will more than likely regret it. The one time I opted not to turn the flywheel I had clutch chatter within 10k miles. I have never done that again.
    Markcal likes this.
  18. Oct 28, 2018 at 9:37 AM
    #58
    LeeVanChief
    I will most likely replace everything. And not to mention the alignment issues I now have, shit might be bent. I went balls out up this thing so there might be other damage I'm not yet aware of.
    And yes I have a therapist and she will listen to this shit
    Markcal, SnowroxKT and elduder like this.
  19. Oct 28, 2018 at 9:38 AM
    #59
    elduder
    Van WA
    Pm'd you, you did right man, seriously.
    The video is funny because they simple don't have a clue, they even check under the hood at the end, like they dont know why smoke is coming from a car that isn't moving while someone "feathers" the clutch.
    Your situation is different for sure. There is no comparison.
  20. Oct 28, 2018 at 9:40 AM
    #60
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You may want to contact your insurance company. All of this may be covered given the circumstances.
    SnowroxKT and Caliph420 like this.
