Burnt plastic smell from under vehicle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kotah, Jan 4, 2018.
  1. Jan 15, 2018 at 12:25 PM
    #41
    Kotah
    Kotah [OP] Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    I will probably just end up changing out the pads with new ones if i cant find nothing else
  2. Jan 15, 2018 at 12:33 PM
    #42
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I don't suppose you checked the oil filter to see if it has a really slow leak and is dropping on the exhaust manifold?
  3. Jan 15, 2018 at 7:58 PM
    #43
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Still have my smell, its intermittent. Is yours there every drive? I've had it as long as I can remember and have been through *everything* and cannot find the source.
  4. Jan 15, 2018 at 8:21 PM
    #44
    Pigpen
    Dan
    Northwest Montana
    I inspect all the important parts on a regular basis (maintenance intervals), and everything looks and performs fine. The smell doesn't worry me.
  5. Jan 15, 2018 at 8:30 PM
    #45
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    I had a similar smell shortly after my last free oil change...turned out the mech left a cut water bottle catch under the filter and the pully was melting it. I found it within a mile, sounds like you would have already found it if this was the source.
  6. Jan 16, 2018 at 1:59 AM
    #46
    Kotah
    TN
    Yes that was one of the first things i checked, oil drain tube is dry
  7. Jan 16, 2018 at 2:01 AM
    #47
    Kotah
    TN
    Yes i can smell it every day especially after braking on steep grades.
  8. Jan 16, 2018 at 2:03 AM
    #48
    Kotah
    TN
    I wouldnt be concered about this if it always smelled but this is something that cropped up in last month
