Burnt rubber smell coming from engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mk4speed, Jun 26, 2021.
  1. Jun 26, 2021 at 4:05 PM
    Mk4speed
    Mk4speed [OP] Member
    Zach
    1996 Tacoma
    anyone know why a burnt rubber smell would be coming out of my engine bay?
    tacotoe likes this.
  2. Jun 26, 2021 at 4:09 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I would guess you have rubber burning .
    Hose or spark plug wire get against the the exhaust manifold.
    It is rubber and not wire insulation ??
    Mmaira2018, 1997tacomav6 and tacotoe like this.
  3. Jun 26, 2021 at 4:09 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Belt slipping?
    JudoJohn likes this.
  4. Jun 26, 2021 at 4:11 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I forget the easy because that should be easy to spot.
    When a belt driven device is no longer working.
    JudoJohn and tacotoe[QUOTED] like this.
  5. Jun 26, 2021 at 4:15 PM
    Mk4speed
    Zach
    1996 Tacoma
    thing is i just had all my belts changed... however my belt does squeak when i accelerate too rapidly, could it be oil i did have a leak and there is still some reminisce.
    tacotoe likes this.
  6. Jun 26, 2021 at 4:19 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Could be not enough belt tension then. At my work we always do a tension check and adjust after a 24hr run on belts.
    Squeak makes me think loose belt, but oil on a belt never a good thing either.
    JudoJohn, Mmaira2018 and Wyoming09 like this.
  7. Jun 26, 2021 at 4:28 PM
    Mk4speed
    Zach
    1996 Tacoma
    what belt do you think would be the culprit then?
  8. Jun 26, 2021 at 4:31 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    No idea, best bet would be shut it down (of course) and check to see if any are looser than the others. Push down on it with thumb or finger in between pulley/sheave.
  9. Jun 26, 2021 at 4:55 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP....Have you opened the hood to look???
    Maybe someone left a condom on the exhaust manifold......
  10. Jun 26, 2021 at 4:55 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Rubber does not expand when heated, it contracts. Perhaps one of your belts is too tight.
    Steves104x4 likes this.
  11. Jun 26, 2021 at 4:58 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Also check coolant level. An overheating engine also smells similar
  12. Jul 1, 2021 at 10:14 AM
    atticus finch
    atticus finch Member
    1996 tacoma
    check the harmonic balancer, if you have a leak it's likely the oil pump cover O-ring and possibly the elastomeric on the balancer has failed. Mine is a `96 and had both. Oil on the belts will let them slip and ultimately when they heat up make bad smells.
  13. Jul 1, 2021 at 12:45 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Sounds like what you are smelling is actually burnt oil. Take a look at the header and pipes to see if there are any burnt oil stain on them.
    Kiloyard likes this.
  14. Jul 1, 2021 at 12:46 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    how many total miles
    a n y recent work done on engine
  15. Jul 1, 2021 at 12:46 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Or if you did an oil change recently, if you spilled any then you'll smell it for awhile after driving around. Accidentally spilled some on my headers once while filling the engine, that was a lovely smell for a few days afterward.
    Nessal[QUOTED] likes this.
  16. Jul 1, 2021 at 1:41 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    My truck smelled like awful burning due to a stray Reese's peanut butter cup on the exhaust manifold.
    My friend's avalon had an awful burning rubber smell after an overfilled brake fluid reservoir spilled over onto the belts.
  17. Jul 1, 2021 at 1:45 PM
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    I had a burning plastic smell in my car and couldn't figure it out.
    I finally discovered a plastic grocery bag melted on my muffler.
    Years later a girl at work was complaing about a burning plastic smell and guess what was melted into her exhaust?
    A grocery bag.
    It was at that moment I realized it is always a grocery bag....
    Jk
  18. Jul 1, 2021 at 2:09 PM
    Strostkovy
    Alex
    White 98 Tacoma
    I pulled a grocery bag out of a customer's brakes once.
  19. Jul 1, 2021 at 2:13 PM
    Jose_Dirte
    Joey
    Green Acres, CO
    I had a German Shepard who discovered he loved attacking helium filled birthday balloons.
    Coincidentally he had ate a balloon on a string.
    He had the string hanging out of his ass so I stepped on it while he was walking away.
    Out came a popped balloon.
    I felt bad for him and never threw another birthday party again.
  20. Jul 1, 2021 at 2:25 PM
    Knute
    Lucky dog. Strings can really FUBAR a dog's digestive system.
    Nessal and Strostkovy like this.
