Burnt rubber smell coming from engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mk4speed, Jun 26, 2021.
  1. Jul 1, 2021 at 2:49 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Could have ended up being a 10k vet bill.
  2. Jul 1, 2021 at 3:21 PM
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    Nah, he ate one balloon, not a dozen.
  3. Jul 1, 2021 at 3:26 PM
    Nessal
    Texas/Bay Area
    Sometimes one does the trick! Even easier on smaller dogs.
  4. Jul 1, 2021 at 3:35 PM
    Jose_Dirte
    Joey
    Green Acres, CO
    That's why I have only ever owned big dogs.
    They're way better at passing balloons.
    Nessal[QUOTED] likes this.
  5. Jul 1, 2021 at 5:28 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I bet you it's the valve cover gaskets leaking oil on the exhaust manifold. It smells. Try gently tightening the valve cover bolts if they're loose. Overtightening will crack your valve covers. If that doesn't work you'll need new valve cover gaskets.
    Nessal likes this.
  6. Jul 1, 2021 at 7:03 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    The loose one.
  7. Jul 2, 2021 at 12:09 AM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    Or the oily one
    JudoJohn[QUOTED] likes this.
  8. Jul 2, 2021 at 2:53 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I'm gonna go with the one that is loose, oily, and smelly.
  9. Jul 2, 2021 at 3:23 PM
    Strostkovy
    Alex
    White 98 Tacoma
    Well you certainly have an affordable taste in hookers
    Taco302[QUOTED] likes this.
  10. Jul 2, 2021 at 3:28 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    I read this thread in under 10 seconds. Am I correct that there is a burning smell the OP found from a dog he ran over that had a ballon in his ass which melted on the manifold while driving thru town looking for hookers?
    I can only read so much before I lose focus and need stuff summarized.
  11. Jul 2, 2021 at 4:35 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I had a small exhaust leak at the upper exhaust flange- not enough to trip a CEL, but just enough that I could smell it, and sometimes see smoke from a cold start. It was noticeable in the cab and out of the cab on short drives. It was more of an exhaust smell rather than rubber, but smells are subjective. I was able to replace the flange gasket (without snapping any studs) and that solved my problem. Anyway, something worth checking and crossing off the list).
    Would also suggest checking the valve cover leak onto the exhaust / heads case. I thought my above problem was due to leaking valve cover gaskets. So I sprayed some foaming engine degreaser in there (when the engine was cold) and hit it with a brush attached to the drill as best I could, rinsed it, and tried to clean up the oil. That didn't fix my exhaust gasket issue, but it did point me in the right direction.
  12. Jul 2, 2021 at 6:27 PM
    Jose_Dirte
    Joey
    Green Acres, CO
    You're reading comprehension is excellent. You interpreted this thread perfectly. LMAO
    Mastiffsrule[QUOTED] likes this.
  13. Jul 2, 2021 at 6:48 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    :facepalm:
