Bushing Maintenance - What wears out? Poly?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Exhaust, Nov 13, 2015.
  1. Nov 13, 2015 at 12:55 PM
    Exhaust
    Exhaust [OP] Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    This winter I'm looking to do some work to my truck. It's about to hit 130k and I figure many of the bushings are on their way out.
    Have any of you guys gone with the energy suspension poly bushings? Which bushings did you find to be the most worn out / in need of replacement? How much firmer is the truck with the polys compared to OEM rubber?
  2. Nov 13, 2015 at 1:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The steering rack bushings are typically the first to go. I used this kit:
  3. Nov 13, 2015 at 3:18 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    rack bushings like said. I went with poly kit
  4. Nov 13, 2015 at 3:59 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    I went with polys for the rack as well. You might look into the control arms bushings as well. I have camburg uppers but for the lower I went with moog replacements. There's poly for those too but are a total bitch to replace. I think there's some that are available, whiteline or something. Idk I read up on that somewhere but forgot what they were called or what's involved. Might search for that. But I don't think anything but oem type replacements are really that necessary for control arms. Maybe if you do a lot of off roading. But bottle Jack method for lowers is the best way to pop them out. Not sure about uppers.
